priv exec level
v-yelmene
we recently removed priv exec level 15,
'no priv exec level 15 show'
But, now 'priv exec level 1 show' appears in running config.
Is there a way to get back to 'default', where no priv exec commands show in config?
thisisshanky
Level 11
Level 11
The default is set at 15 for the level. So I think you should set it back to priv exec level 15 show, to go back to defaults.
Or did I get your question wrong ???
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
v-yelmene
As far as I know, user exec level (1) can use 'show' commands. Implementing this command;
'priv exec level 15 show'
requires the user to be in "enable" mode in order to use show commands. I wanted to go back to default of using show commands at user exec level (1), however this forces this command to show in running config;
and I was wondering why it does not appear in default configurations that have not have priv level modifications.
u can easily remove the priv exec level command by using the following command ...
router(config)#privilege exec reset "the command u want to remove"
hope this will definitely solve ur problem...
Amit Shrivastava
Network Engineer
Reliance Infocomm
