01-03-2004 05:43 AM - edited 03-02-2019 12:39 PM
Hi Experts, I have a problem configuring a Cisco 2610Xm router with a 4bri isdn module to call another Cisco 2610Xm with 4bri... I'm using dialer profiles with 4 dialer string options, but the caller use only 2 number (4 isdn channels) and ignore the other 2 number... I wish to use all the available bandwidth... can someone give me a possible configuration?
01-03-2004 08:43 AM
I think you had a previous post about this, apparently your problem still exists. I remember that you used round-robin as your dialer order but only the first two numbers were called. Stupid question maybe but can you try and switch the numbers around, make the 3rd and 4th number the 1st and 2nd number respectively, just to make sure that all numbers are actually valid ?
Georg
01-04-2004 11:09 PM
Could you post your configuration?
Ashok.
01-05-2004 12:13 AM
I have already tried to change the order of the "dialer string" numbres, I've tried different values for "dialer load-threshold" and "dialer order" but the problem still exists...
I post the actual configuration:
version 12.2
service password-encryption
hostname CALLER
enable password 7 ...
username CALLED password 7 ...
ip subnet-zero
no ip domain lookup
isdn switch-type basic-net3
interface FastEthernet0/0
ip address 10.X.Y.Z 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
no fair-queue
interface BRI1/0
no ip address
encapsulation ppp
dialer pool-member 1
no fair-queue
no cdp enable
ppp authentication chap
ppp multilink
interface BRI1/1
no ip address
encapsulation ppp
no fair-queue
no cdp enable
ppp multilink
interface BRI1/2
no ip address
encapsulation ppp
no fair-queue
no cdp enable
ppp multilink
interface BRI1/3
no ip address
encapsulation ppp
no fair-queue
no cdp enable
ppp multilink
interface Dialer1
ip address negotiated
encapsulation ppp
load-interval 30
dialer pool 1
dialer remote-name CALLED
dialer order round-robin
dialer idle-timeout 600
dialer string 0...1
dialer string 0...2
dialer string 0...3
dialer string 0...4
dialer load-threshold 10 either
dialer-group 1
no cdp enable
ppp multilink
ip classless
ip route 10.A.B.0 255.255.255.0 Dialer1
no ip http server
ip pim bidir-enable
dialer-list 1 protocol ip permit
line con 0
line aux 0
line vty 0 4
password 7 ...
login
end
01-06-2004 03:14 AM
Do you want to use all channels at once? Because "dialer order round-robin" dials only a single dial string which is followed in the configuration by last successful dial string. In this case also, you can observe only at most 2 BRI channels to be used.
Regards..
Ashok.
01-07-2004 01:25 AM
if I understood Cisco docs, "round robin" option implies that "dialer strings" are all used: the first, the second, the third, the fourth, than the first again and so on... is that correct? the problem is that the router use the first, the second, than the first and the second again, ignoring the third and fourth numbers... this result in an half use of the entire bandwidth.
I've tried to use the "sequential" option of "dialer order" but the result is the same...
01-07-2004 06:50 AM
No, all dial strings are not used at once. This is from Cisco doc only..
interface Dialer0
ip address 10.1.1.130 255.255.255.0
encapsulation ppp
dialer pool 1
dialer string 1904
dialer string 1905
dialer string 1906
dialer string 1907
dialer-group 1
If in a previous attempt to dial network 10.1.1.130 the telephone number 1906 was successful, because the dial order is set to round-robin, the next attempt to dial network 10.1.1.130 will start with the 1907 telephone number.
It's like if you dialed and connected once to 10.1.1.130 with 1906 SUCCESSFULLY and disconnected. And when you want to reconnect then after, then it will use the next string 1907.
Regards...
Ashok.
01-07-2004 08:33 AM
and if number 1906 is successfull, the next call is for 1907 (bandwidth-on-demand); if is successfull, the next will be for 1904, it's right? If it is, I expect that the router work in this way... but it doesn't... It call 1904 (success), than 1905, 1904, 1905, and so on... Is it the correct work for round robin?
01-08-2004 05:49 AM
As far as i know, that command used to serve to give multiple strings to reach one destination. It always dials the string followed to prev successful dial string to reach the destination. There is no information related according to bandwidth on demand for this command. If you have seen that one, could you please provide me that link?
Regards...
Ashok.
01-20-2004 04:02 AM
Hi experts,
the problem was solved upgrading the IOS: the original version was 12.2(8)T10, the new one 12.3.5a
Bye
