09-09-2003 10:45 AM - edited 03-02-2019 10:13 AM
Hi all,
I'm trying to add all of my Cisco devices configuration files in my RME database. Unfortunately some of them (isolated cases) wont cooperate !
One of them is a Catalyst 2950 with IOS ver. 12.0(5.3)WC(1). When I check this device attributes no errors are shown (r/w community OK, Local user OK, enable OK). But if i try to retreive the configuration in RME it shows "Failed".
What could be wrong here?!
Is there a list of things that must be enabled on the devices to allow config files retreival ?!
Thx for any advices !
09-09-2003 10:53 AM
RME and IDU version?. When you do an Update Archive on this device, what is the reason of archive failure shown in RME?
09-09-2003 11:27 AM
Resource Manager Essentials 3.5 Incremental Device Update 5.0
It just shows "failed"...
When i do a "Check Devices Attributes" no errors are shown.
