Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Problem adding T3 Bulk Distribution on 8850..Help
I thought that I had read everything to get this working but I am at a stone wall.
Have an existing 8850 with SMR-3CT3 card and AUSM-8 cards. The previous people had configured the first two T3 cards and they are all working fine. We are now starting into the thrid T3 and nothing is working. The example I am trying to get to work is Channel 16 on the T3.3, I want to cross to line card 11 line 8. At which point I want to take three ATM PVC's and send one to the first router card, the second to the second router card in the 8850, and the third to an outbound AUSM-8T card for voice to a 3810. Same as all of the rest. But it just does not seem to come up and the dspcons indicates that the connection FAILED.
I have followed the cookbooks as far as I can, but I have not seen this specifically walked through.
Any pointers will be greatly appreciated
For what it is worth, we are running 1.1.32 on the PMX cards, but do not tell me to upgrade at this time.
Telco indicates that the connection is coming in clean to the T3.
1 REPLY
Re: Problem adding T3 Bulk Distribution on 8850..Help
The following link gives the config procedure for SMR-3CT3 card.
http://www.cisco.com/univercd/cc/td/doc/product/wanbu/mgx8850/instcnf/6c8800up.htm#12327
AUSM/B IMA Troubleshooting Guide
http://www.cisco.com/warp/public/74/164.html
89
