Community Member
Problem Backup IOS
hello i have a problem i need backup de IOS the switch core, but the file is big and i cant backup with the tftp and i browse in the web and find
the meybe solutions and the maybe solution is the FTP but i dont know how? help please
Problem Backup IOS
What TFTP server do you use?
The 3com TFTP "3CDaemon" works also with files of large dimension (e.g. 40 Mbyte).
If you want use FTP try the command "copy flash: ftp:".
You must specify some ftp parameters first if necessary:
ftp username ...
ftp passive mode
You can find more informations at this link:
https://supportforums.cisco.com/docs/DOC-6079
Regards.
Silver
Problem Backup IOS
Get a better TFTP server.
The Solar Winds one supports files up to 4 Gb in size with Cisco routers which support variable block sizes in TFTP transfers (most recent IOS's do).
Older TFTP servers (and older clients) were limited to 32 Mb file sizes because of the fixed block size used in the transfer.
Cheers.
474
