Problem between 2948GL3 and User Tracking
A customer has got 3 2948GL3 (and others equipements like 3548 & 3524 XL) in his network.
The version used on 2948GL3 is :
IOS (tm) L3 Switch/Router Software (CAT2948G-IN-M), Version 12.0(14)W5(20) RELE
ASE SOFTWARE
All equipment are well discovered with map.
But i got a problem with 2948 GL3 and User Tracking :
No equipement have found behind 2948GL3
and so User Tracking cannot discover any users or hosts from 2948GL3.
So we can't know what are adress mac connected to 2948GL3.
I haven't find bug on this equipement.
(http://www.cisco.com/en/US/products/sw/cscowork/ps563/prod_release_note09186a008007fe26.html#xtocid7)
http://www.cisco.com/en/US/products/sw/cscowork/ps563/products_user_guide_chapter09186a00800ca16a.html#xtocid14
When i look this url :
http://www.cisco.com/en/US/products/sw/cscowork/ps563/products_tech_note09186a0080094949.shtml#mac
it says that
ANI discovers hosts by reading the CAM tables from the discovered switches. If UserTracker is not listing some of the hosts in the network, you need to investigate where the discovery went wrong.
Select a missing MAC address at random and use the following example to determine where the discovery went wrong:
Switch1# show cam dynamic 2/2
But on the 2948 GL3 this command doesn't work.
How to display mac-address behind 2948GL3 ?
Or is it possible ?
Thank You.
  • Other Network Infrastructure Subjects
Blue
Re: Problem between 2948GL3 and User Tracking
Per: http://www.cisco.com/warp/public/473/47.html you can try using the command:
show epc patricia interface fast 1 mac. You can use the show epc patricia interface mac to see the actual internal state of the bridge table entries (the patricia tree is the data structure used to store and access the bridge table).
Thank You for Your answer,
But i can't see the interaction between this command and usertracking.
So i think i will open a (new) case.
91
