Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Problem changing the IP of switch 6509
I have the following problem:
I was changing to the IP direction Management of switch catalyst 6509, and forgets to clear the authentication to Tacas.
Trying to solve the problem when attempt to connect by console, I have access it is to the MSFC and not to prompt of switch.
I cannot make telnet to switch.
Exists some commando in IOS Msfc like “Session 15” in CAt Os.
Why in the console appears to me prompt of msfc and not the one of switch?
Some idea of how I can solve this problem?
1 ACCEPTED SOLUTION
Re: Problem changing the IP of switch 6509
Probably you issued a "switch console" which took you to the MSFC's virtual console. From the console session of MSFC, try issuing a "Control CCC" and it should disconnect the virtual console session and take you back to the Switch.
1 REPLY
86
