Problem copying c3660-i-mz.121^[O-5.T.bin
I need to back up the IOS on my 3662 to a Flash Card. The "sh flash" shows c3660-i-mz.121^[O-5.T.bin. The "dir flash:" from the ROMMON mode shows c3660-i-mz.121-5.T.bin. I received the following error when I try to copy either file to slot1: (No such file or directory). Can anyone help?
rommon 1 > dir flash:
File size Checksum File name
5861672 bytes (0x597128) 0x0542 c3660-i-mz.121-5.T.bin
830 bytes (0x33e) 0x0f52 n
Router#copy flash slot1:
Source filename []? c3660-i-mz.121-5.T.bin
Destination filename [c3660-i-mz.121-5.T.bin]?
Erase slot1: before copying? [confirm]
Erasing the slot1 filesystem will remove all files! Continue? [confirm]
Erasing device... eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee ...erased
Erase of slot1: complete
%Error opening flash:c3660-i-mz.121-5.T.bin (No such file or directory)
Router#sh flash
System flash directory:
File Length Name/status
1 5861672 c3660-i-mz.121^[O-5.T.bin
2 830 n
[5862632 bytes used, 2525976 available, 8388608 total]
8192K bytes of processor board System flash (Read/Write)
Router#copy flash slot0:
Flash card inserted. Reading filesystem...done.
Source filename [c3660-i-mz.121^[O-5.T.bin]?
Destination filename [c3660-i-mz.121^[O-5.T.bin]?
Erase slot0: before copying? [confirm]
Erasing the slot0 filesystem will remove all files! Continue? [confirm]
Erase of slot0: complete
%Error opening flash:c3660-i-mz.121^[O-5.T.bin (No such file or directory)
Router#
Bronze
Re: Problem copying c3660-i-mz.121^[O-5.T.bin
Try adding a : after flash, as in copy flash: slot0:
Another option would be to specify the filename in the copy statement -
copy flash:c3660-i-mz.121^[O-5.T.bin slot0:
Thanks for your help. I tried your suggestions, but I received the same results. I think I will get new IOS for the router.
Router#copy flash: slot0:
Router#
Router#copy flash:c3660-i-mz.121^[O-5.T.bin slot0:c3660-i-mz.121^[O-5.T.bin
Erase slot0: before copying? [confirm]n
Router#
131
