Problem for PPP on Leased Line
I have leased line back to back routers.I have configured dialer interface although dialer interface is mostly used on switched ckts.But I am using here on leased line bavck to back.Now what happens after restting the interface physical
It get disconnect after idle-timeout so I have made dilaer list to define interesting traffic also but still I am not able to trigger the call so dilaer interface timesout after being idle.I have used Map command
Map protocol ip <ip> name <remote side> broadcast ..I have not defined any string.I cannot define any string in above command as I have leased line ,no number to dial.
During which the call is active i am able to transfer data but if it times out after idle time specified I am unable to activate the call.
Please do help
Re: Problem for PPP on Leased Line
We need to see the config on both the routers.
You can turn on following debug to know what is going on.
debug ppp negotiation
debug dialer
debug ppp authentication
Capture it when the call gets disconnected and when you try the interesting traffic (you can use ping for that) to activate the line again.
Hi sorry for delay here is my configuration and debug o/p also.
Munit
Configuration of router 1:
router1#sh run
Building configuration...
Current configuration : 1209 bytes
version 12.2
no parser cache
service timestamps debug uptime
service timestamps log uptime
hostname router1
no logging console
enable secret 5 $1$xYa1$1.YkO1.NXT1epX8oSH8KQ1
username router2 password 0 abc
ip subnet-zero
frame-relay de-list 3 protocol ip gt 500
interface Loopback0
ip address 192.168.10.2 255.255.255.0
interface FastEthernet0
ip address 10.77.152.223 255.255.255.0
speed auto
interface Serial0
no ip address
encapsulation ppp
dialer in-band
dialer rotary-group 1
pulse-time 1
interface Serial1
no ip address
encapsulation ppp
shutdown
dialer in-band
pulse-time 1
interface Dialer1
ip unnumbered Loopback0
encapsulation ppp
dialer in-band
dialer idle-timeout 30
dialer map ip 192.168.20.1 name router2 broadcast
dialer-group 1
ppp authentication chap
ppp direction callout
ip classless
ip route 0.0.0.0 0.0.0.0 10.77.152.129
ip route 192.168.20.1 255.255.255.255 Dialer1
no ip http server
access-list 100 permit ip any any
dialer-list 1 protocol ip list 100
line con 0
line aux 0
line vty 0 4
exec-timeout 200 0
password lab
login
line vty 5 15
login
no scheduler allocate
end
router1#
similar is configuration on router 2
Debug ppp nego o/p on router 1
4:39:54: %LINK-3-UPDOWN: Interface Serial0, changed state to up
4:39:54: Se0 PPP: Using configured call direction
4:39:54: Se0 PPP: Treating connection as a callout
4:39:54: Se0 PPP: Phase is ESTABLISHING, Active Open [0 sess, 1 load]
4:39:54: Se0 LCP: O CONFREQ [Closed] id 203 len 15
4:39:54: Se0 LCP: AuthProto CHAP (0x0305C22305)
4:39:54: Se0 LCP: MagicNumber 0x03B9ED37 (0x050603B9ED37)
4:39:54: Se0 LCP: I CONFREQ [REQsent] id 44 len 15
4:39:54: Se0 LCP: MagicNumber 0x00FF543D (0x050600FF543D)
4:39:54: Se0 LCP: O CONFACK [REQsent] id 44 len 15
4:39:54: Se0 LCP: I CONFACK [ACKsent] id 203 len 15
4:39:54: Se0 LCP: State is Open
4:39:54: Se0 PPP: Phase is AUTHENTICATING, by both [0 sess, 1 load]
4:39:54: Se0 CHAP: O CHALLENGE id 240 len 28 from "router1"
4:39:54: Se0 CHAP: I CHALLENGE id 35 len 28 from "router2"
4:39:54: Se0 CHAP: O RESPONSE id 35 len 28 from "router1"
4:39:54: Se0 CHAP: I SUCCESS id 35 len 4
4:39:54: Se0 CHAP: I RESPONSE id 240 len 28 from "router2"
4:39:54: Se0 CHAP: O SUCCESS id 240 len 4
4:39:54: Se0 PPP: Phase is UP [0 sess, 1 load]
4:39:54: Se0 IPCP: O CONFREQ [Closed] id 8 len 10
4:39:54: Se0 IPCP: Address 192.168.10.2 (0x0306C0A80A02)
4:39:54: Se0 CDPCP: O CONFREQ [Closed] id 8 len 4
4:39:54: Se0 IPCP: I CONFREQ [REQsent] id 1 len 10
4:39:54: Se0 IPCP: Address 192.168.20.1 (0x0306C0A81401)
4:39:54: Se0 IPCP: O CONFACK [REQsent] id 1 len 10
4:39:54: Se0 IPCP: I CONFACK [ACKsent] id 8 len 10
4:39:54: Se0 IPCP: State is Open
4:39:54: Se0 LCP: I PROTREJ [Open] id 45 len 10 protocol CDPCP (0x820701080004)
4:39:54: Se0 CDPCP: State is Closed
4:39:54: Di1 IPCP: Install route to 192.168.20.1
4:39:55: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed state
to up
router1#show dialer
Di1 - dialer type = IN-BAND SYNC NO-PARITY
Idle timer (30 secs), Fast idle timer (20 secs)
Wait for carrier (30 secs), Re-enable (15 secs)
Number of active calls = 1
Dial String Successes Failures Last DNIS
Se0 - dialer type = IN-BAND SYNC NO-PARITY
Rotary group 1, priority 0
Dialer state is data link layer up
Time until disconnect 24 secs( this is decreasing after it expires I cant ping also)
Connected to (router2)
Se1 - dialer type = IN-BAND SYNC NO-PARITY
Dialer state is shutdown
If I ping during this remaining time then the timer is reset idle timer but once it times off I am unable to generate the interesting traffic.
I have enabled now debug ip packet detail when the idle disconnect time reaches zero it gives me this o/p.Problem is I am unable to generate interesting traffic after that will initiate call.Please help
router1#ping 192.168.20.1
Sending 5, 100-byte ICMP Echos to 192.168.20.1, timeout is 2 seconds:
00:07:21: IP: s=10.10.10.13 (FastEthernet0), d=255.255.255.255, len 49, rcvd 2
00:07:21: UDP src=2606, dst=69
00:07:21: IP: s=192.168.10.2 (local), d=192.168.20.1 (Dialer1), len 100, sendi
00:07:21: ICMP type=8, code=0
00:07:21: IP: s=192.168.10.2 (local), d=192.168.20.1 (Dialer1), len 100, encap
lation failed
00:07:22: IP: s=10.10.10.13 (FastEthernet0), d=255.255.255.255, len 49, rcvd 2
00:07:22: UDP src=9906, dst=69.
00:07:23: IP: s=192.168.10.2 (local), d=192.168.20.1 (Dialer1), len 100, sendi
00:07:23: ICMP type=8, code=0
00:07:23: IP: s=192.168.10.2 (local), d=192.168.20.1 (Dialer1), len 100, encap
lation failed
00:07:23: ICMP type=8, code=0.
00:07:25: IP: s=192.168.10.2 (local), d=192.168.20.1 (Dialer1), len 100, sendi
00:07:25: ICMP type=8, code=0
00:07:25: IP: s=192.168.10.2 (local), d=192.168.20.1 (Dialer1), len 100, encap
lation failed
00:07:26: IP: s=10.10.10.13 (FastEthernet0), d=255.255.255.255, len 49, rcvd 2
00:07:26: UDP src=2606, dst=69.
00:07:27: IP: s=10.10.10.13 (FastEthernet0), d=255.255.255.255, len 49, rcvd 2
00:07:27: UDP src=9906, dst=69
00:07:27: IP: s=192.168.10.2 (local), d=192.168.20.1 (Dialer1), len 100, sendi
00:07:27: ICMP type=8, code=0
00:07:27: IP: s=192.168.10.2 (local), d=192.168.20.1 (Dialer1), len 100, encap
lation failed
00:07:27: ICMP type=8, code=0.
00:07:29: IP: s=192.168.10.2 (local), d=192.168.20.1 (Dialer1), len 100, sendi
00:07:29: ICMP type=8, code=0
00:07:29: IP: s=192.168.10.2 (local), d=192.168.20.1 (Dialer1), len 100, encap
lation failed
00:07:29: ICMP type=8, code=0.
Success rate is 0 percent (0/5)
router1#
You have ip address mismatch..router1 has ip address 192.168.10.0 and other side of the link have 192.168.20.0..that is the probelm..Pl. change the ip address at router1 to 192.168.20.2..it will work..Not sure why you use "unnumbered loopback" instead of ip address config under the dialer interface..
Hi Mr. Patel,
Thanx for instant reply.See I tried using directly putting ip address to dialer interface also on both sides that too in the same subnet
like router1(config)int dialer1,ip address 1.1.1.1
router2(config) int dialer 2,ip address 2.2.2.2
Above mentioned way also i tried.when i reset the interface it works but suppose during idle disconect time i dont send any traffic then I am unable to initiate a call as weused to do in case of isdn.same error messages here also comes if idle disconnect timer is expired.Moreover if any traffic is sent during the idle disconnect timer then it resets the timer.Everything is fine only question is that after dialer interface goes to idle state can i initiate call,I am unable to do here in case of leased lines.Moreover the configuration which i have showed you is from the following link which shows how to do load balacing on leased lines using ppp.
http://www.cisco.com/warp/public/793/access_dial/pppmultilink.html
Are we able to do it .
waiting for u reply
Munit
109
