Community Member
Problem formatting 64m ATA Flash cards on 6500 Sup2/MSFC2
I'm trying to format the 64 meg cards I have in my Sup2 but it's not working. I'm issuing the "format slot0:" command and it returns with:
C6509-EEC173_1-CORE1#format slot0:
Format operation may take a while. Continue? [confirm]
Format operation will destroy all data in "slot0:". Continue? [confirm]
Enter volume ID (up to 64 chars)[default slot0]: C6509-EEC173_1-CORE1
%Error formatting slot0 (Unspecified error)
From what I've read it says this card is supported and I'm running the required ROMMON software release 7.1(1).
Any ideas?
1 ACCEPTED SOLUTION
Purple
Re: Problem formatting 64m ATA Flash cards on 6500 Sup2/MSFC2
Did you try format disk0: ?
Purple
Community Member
Works great, I completely forgot the ATA are flashdisks.
As pointed out by Glen:
64-MB ATA Flash PC card (MEM-C6K-ATA-1-64M=)—Only supported on Supervisor Engine 2. The device name is disk0: and the card requires ROMMON version 7.1(1) and later releases.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/relnotes/ol_4498.htm#wp410962
Also, I think Either you are running IOS or in MSFC when you are running this command (suggdested by the command). In either of the case you have to use sup-disk0: to format it.
regards,
-amit singh
359
