Problem in assaining IP address
I have a Cisco 2610 with WIC2T and 1 PRI Module.
When the remote client (BRI ISDN) client logs in all the clients get the same IP assained. The following is the config of the router. Please advice and help.
ip multicast-routing
isdn switch-type primary-net5
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-31
interface Loopback0
no ip address
interface FastEthernet0/0
ip address 172.168.10.254 255.255.255.0
ip access-group 101 in
ip nat inside
no ip mroute-cache
speed auto
full-duplex
interface Serial0/0
ip address 192.168.200.22 255.255.255.252
no ip mroute-cache
no fair-queue
interface Serial0/1
bandwidth 2000000
no ip address
no ip mroute-cache
shutdown
interface Serial1/0:15
no ip address
encapsulation ppp
load-interval 60
dialer pool-member 1
interface Dialer1
ip unnumbered FastEthernet0/0
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 3500
dialer-group 1
peer default ip address pool isdn
ppp authentication chap
ip local pool isdn 172.168.10.200 172.168.10.240
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.200.21
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 172.17.0.0 255.255.0.0 192.168.200.21
ip route 172.168.0.0 255.255.0.0 172.168.10.5
ip http server
ip pim bidir-enable
access-list 1 permit 172.168.10.0 0.0.0.255
access-list 101 permit ip any any
dialer-list 1 protocol ip list 101
line con 0
line aux 0
line vty 0 4
password xxxx
login
end
1 REPLY
Bronze
Re: Problem in assaining IP address
Hi, are your clients all logging in with the same username?
If so try adding the following commands to your dialer config
ppp ipcp ignore-map
ppp ipcp unique-address
dialer mult-map-same-name (hidden command, won't tab)
Haven't tried them lately, with later IOS it may be that all you need is
ppp ipcp username unique
hth
128
