Community Member
Problem in cisco 1700 router
> I wish to make an enquiry about the Cisco 1720 router. There seem like when
> I turn on the router for long period of time, it may lost connection with
> the network. Is 1720 router easily get heated up?? Whenever there's a lost
> of connection, I restarted the router and the connection is back. I'm using
> ADSL card to connect to my office's network. Sometimes I'll change another
> router so that the connection is resume. Is my router spoilt or is it
> because of other reason?? Kindly help. Thanks...
Re: Problem in cisco 1700 router
What do you mean with losing connection?
Is it the LAN-interface or is the ADSL connection dropped?
In case of the ADSL-side you do not need to worry. I have observed this behaviour also. Could be a providers issue or IOS-related.
The advice for this is: Stay current with your IOS release.
I have never seen a LAN interface losing connection. Normally this should not happen.
Community Member
It is the ADSL connection drop. I'm using IOS ver 12.0. Is it good enough??
Community Member
Greetings-
I have used 1700s on a couple of occations and have not had any "over heating" issues. I have even had them in some un-friendly closets where they were exposed to higher then ideal heat levels without problems.
Best of Luck,
~John
115
