Problem in defining Class-map
we r using a 3662 with ios c3660-ik8s-mz.122-3.bin.
i m tyring to use the workaround given in cisco site to avoid Nachi worm.but i could able to define some options which is listed in cisco site.can any one pls let me know is ther any equivalent command or value ??
im getting the following output under class map.i m not geting any thing like match packet length/length so that i can match the packet length.
pls help me with some solution...
01(config-cmap)#match ?
access-group Access group
any Any packets
class-map Class map
cos IEEE 802.1Q/ISL class of service/user priority value
destination-address Destination address
input-interface Select an input interface to match
ip IP specific values
mpls Multi Protocol Label Switching specific values
not Negate this match result
protocol Protocol
qos-group Qos-group
source-address Source address
regds
prem
Silver
Re: Problem in defining Class-map
I think the workaround is using a route-map not a class map
access-list 199 permit icmp any any echo
access-list 199 permit icmp any any echo-reply
route-map nachi-worm permit 10
! --- match ICMP echo requests and replies (type 0 & 8)
match ip address 199
! --- match 92 bytes sized packets
match length 92 92
! --- drop the packet
set interface Null0
Class maps are used to define a traffic class, but not based on packet length. You will have to use a route map instead.
105
