06-25-2002 07:55 AM - edited 03-01-2019 10:34 PM
Hi there,
We have a Cisco 2662 with NM-8AM and IOS version 12.8(T4). When a remote user dials in with W95/W98/w2k the system asks for the number to be called back. After a few seconds the client is called back and the connection is made. So far so good.
But in debug information I see that my chat-script "modem-callback" is't call. Why? (see first debug listing).
Other problem is when a remote user dials in with W95/W98/w2k the system asks for the number to be called back, but the client press escape (cancel) for direct connection (without callback). In this case, connection is droped (see second debug listing). Why? In old IOS version of IOS (12.0(T1)) it worked fine. We don't change configuration.
Do you have seen similar problems like this or does anyone know how to configure DialIn for this situations?
Thanks in advance for helping us.
Our config is:
version 12.2
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname bnm
logging buffered 10000 debugging
aaa new-model
aaa authentication login admins local
aaa authentication ppp dialup group radius local
aaa authorization network default group radius local
aaa accounting network default start-stop group radius
aaa session-id common
enable secret 5 $1$u3EP$F5l49mkVFKmhf6GEXdy2C/
enable password 7 1511021F457C7B742A3D38
username admin password 7 120D3044065A5E57
username BackUp password 7 121D0C617E1E1C
clock timezone OMT 2
clock summer-time OMTS recurring last Sun Mar 3:00 last Sun Oct 3:00
modem country microcom_hdms europe
ip subnet-zero
no ip source-route
no ip domain-lookup
ip domain-name bn.org
chat-script offhook "" "ATH1" OK
chat-script modem-callback ABORT ERROR ABORT BUSY ABORT "NO ANSWER" "" "ATH" OK "ATDT\T" TIMEOUT 30 CONNECT
modemcap entry MY_MODEMCAP:MSC=&F&D2
fax interface-type fax-mail
mta receive maximum-recipients 0
interface Loopback0
ip address 172.16.0.247 255.255.255.255
interface Group-Async2
description multicanal line (tel.225008)
ip unnumbered Loopback0
no ip unreachables
ip nat outside
ip audit AUDIT.1 in
encapsulation ppp
no ip route-cache
ip tcp header-compression passive
no ip mroute-cache
dialer in-band
dialer idle-timeout 300
dialer-group 1
async mode dedicated
peer default ip address pool dialup1
pulse-time 3
compress mppc
ppp max-bad-auth 3
ppp callback accept
ppp authentication chap dialup
group-range 33 40
dialer-list 1 protocol ip permit
radius-server host 192.168.194.129 auth-port 1645 acct-port 1646
radius-server retransmit 3
radius-server key 7 073326466607310C391A5E5450273327716B170C190C1C5058525E
call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
line 33 40
session-timeout 30
absolute-timeout 240
script modem-off-hook offhook
script callback modem-callback
login authentication admins
modem InOut
modem autoconfigure type mica
transport input all
autoselect during-login
autoselect ppp
callback nodsr-wait 10000
stopbits 1
flowcontrol hardware
line aux 0
line vty 0 4
access-class 5 in
password 7 030752185459234243
line vty 5 15
end
Debug setings is:
General OS:
Modem control/process activation debugging is on
AAA Authorization debugging is on
CSM Modem Management:
Modem Management Call Switching Module debugging is on
PPP:
PPP protocol negotiation debugging is on
PPP Callback Control Protocol debugging is on
Chat Scripts:
Chat scripts activity debugging is on
Callback:
Callback activity debugging is on
Radius protocol debugging is on
Radius packet protocol debugging is on
Start first debug listing ==================================================================================
CSM_ANALOG_MODEM_IDLE: MODEM_STARTING_CONNECT at slot 1, port 4
Modem 1/4 Mcom: in modem state 'Dialing/Answering'
ANALOG_CONNECT_INITIATED: MODEM_ANALOG_CALL_IN at slot 1, port 4
Modem 1/4 Mcom: in modem state 'Incoming ring'
Modem 1/4 Mcom: in modem state 'Waiting for Carrier'
Modem 1/4 Mcom: in modem state 'Connected'
ANALOG_CONNECT_INITIATED: MODEM_CONNECTED at slot 1, port 4
Call Handle failed for Modem 1/4
Modem 1/4 Mcom: CONNECT at 28800/24000(Tx/Rx), V34, LAPM, V42bis, Answer
TTY37: DSR came up
Modem 1/4 Mcom: switching to PPP mode
TTY37: no timer type 1 to destroy
TTY37: no timer type 0 to destroy
TTY37: create timer type 2, 1800 seconds
TTY37: create timer type 0, 14400 seconds
tty37: Modem: IDLE->(unknown)
As37 LCP: I CONFREQ [Closed] id 1 len 23
As37 LCP: ACCM 0x00000000 (0x020600000000)
As37 LCP: MagicNumber 0x32F108D4 (0x050632F108D4)
As37 LCP: PFC (0x0702)
As37 LCP: ACFC (0x0802)
As37 LCP: Callback 6 (0x0D0306)
As37 LCP: Lower layer not up, Fast Starting
As37 PPP: Treating connection as a callin
As37 PPP: Phase is ESTABLISHING, Passive Open
As37 LCP: State is Listen
Modem 1/4 Mcom: PPP escape map: Tx map = FFFFFFFF, Rx map = 0
As37 LCP: O CONFREQ [Listen] id 71 len 25
As37 LCP: ACCM 0x000A0000 (0x0206000A0000)
As37 LCP: AuthProto CHAP (0x0305C22305)
As37 LCP: MagicNumber 0x15589567 (0x050615589567)
As37 LCP: O CONFACK [Listen] id 1 len 23
%LINK-3-UPDOWN: Interface Async37, changed state to up
As37 LCP: I CONFACK [ACKsent] id 71 len 25
As37 LCP: State is Open
Modem 1/4 Mcom: PPP escape map: Tx map = 0, Rx map = 0
As37 MCB: Initialize
As37 MCB: Flush
As37 PPP: Phase is AUTHENTICATING, by this end
As37 CHAP: O CHALLENGE id 28 len 24 from "bnm"
As37 LCP: I IDENTIFY [Open] id 2 len 18 magic 0x32F108D4 MSRASV5.00
As37 CHAP: I RESPONSE id 28 len 34 from ".rig.auto.nbm"
As37 PPP: Phase is FORWARDING, Attempting Forward
As37 PPP: Phase is AUTHENTICATING, Unauthenticated User
RADIUS/ENCODE(000004A8): acct_session_id: 1438
RADIUS(000004A8): sending
RADIUS: Send to unknown id 28 212.56.194.129:1645, Access-Request, len 91
RADIUS: authenticator 63 AF 2A F1 7B FE C5 5E - BD 93 B9 1D C7 87 15 E4
RADIUS: Framed-Protocol [7] 6 PPP [1]
RADIUS: User-Name [1] 15 ".rig.auto.nbm"
RADIUS: CHAP-Password [3] 19 *
RADIUS: NAS-Port [5] 6 37
RADIUS: NAS-Port-Type [61] 6 Async [0]
RADIUS: Calling-Station-Id [31] 7 "async"
RADIUS: Service-Type [6] 6 Framed [2]
RADIUS: NAS-IP-Address [4] 6 212.56.194.130
RADIUS: Received from id 28 212.56.194.129:1645, Access-Accept, len 136
RADIUS: authenticator 66 80 28 48 6D 4A 7D 81 - 05 B8 BC 03 2D C2 D2 A8
RADIUS: Framed-IP-Address [8] 6 192.168.5.7
RADIUS: Vendor, Cisco [26] 20
RADIUS: Cisco AVpair [1] 14 "ip:inacl=106"
RADIUS: Idle-Timeout [28] 6 1800
RADIUS: Vendor, Cisco [26] 34
RADIUS: Cisco AVpair [1] 28 "ip:dns-servers=192.168.0.1"
RADIUS: Session-Timeout [27] 6 7200
RADIUS: Vendor, Cisco [26] 32
RADIUS: Cisco AVpair [1] 26 "lcp:callback-dialstring="
RADIUS: Received from id 4A8
As37 PPP/AAA: Check Attr: addr
As37 PPP/AAA: Check Attr: Framed-Protocol
As37 PPP/AAA: Check Attr: service-type
As37 PPP/AAA: Check Attr: inacl:Peruser
As37 PPP/AAA: Check Attr: idletime:Peruser
As37 PPP/AAA: Check Attr: dns-servers
As37 PPP/AAA: Check Attr: timeout:Peruser
As37 PPP/AAA: Check Attr: callback-dialstring
As37 PPP: Phase is AUTHENTICATING, Authenticated User
As37 AAA/AUTHOR/LCP: Process Author
As37 AAA/AUTHOR/LCP: Process Attr: idletime
AAA/AUTHOR: Processing PerUser AV idletime
As37 AAA/AUTHOR/LCP: Process Attr: timeout
AAA/AUTHOR: Processing PerUser AV timeout
As37 AAA/AUTHOR/LCP: Process Attr: callback-dialstring
As37 CHAP: O SUCCESS id 28 len 4
As37 MCB: Start
As37 MCB: User .rig.auto.nbm Callback Number - Client ANY
As37 MCB: Newstate 0-INIT -> 2-WAIT_RESPONSE
Async37 PPP: O MCB Request(1) id 44 len 9
Async37 MCB: O 1 2C 0 9 2 5 0 1 0
As37 MCB: O Request Id 44 Callback Type Client-Num delay 0
As37 PPP: Phase is CBCP
RADIUS/ENCODE(000004A8): Unsupported AAA attribute start_time
RADIUS/ENCODE(000004A8): Unsupported AAA attribute timezone
RADIUS: Send to unknown id 237 212.56.194.129:1646, Accounting-Request, len 135
RADIUS: authenticator 64 83 7E BD DA 5B 65 92 - 61 4D 0B 01 4D 4A 59 12
RADIUS: Acct-Session-Id [44] 10 "0000059E"
RADIUS: Connect-Info [77] 29 "28800/24000 V34/V42bis/LAPM"
RADIUS: Authentic [45] 6 RADIUS [1]
RADIUS: Acct-Status-Type [40] 6 Start [1]
RADIUS: Event-Timestamp [55] 6 1025017394
RADIUS: Acct-Delay-Time [41] 6 0
RADIUS: Received from id 237 212.56.194.129:1646, Accounting-response, len 20
RADIUS: authenticator 70 32 56 D1 49 34 17 23 - 58 0F 57 99 27 76 5A 38
Async37 PPP: I MCB Response(2) id 44 len 15
Async37 MCB: I 2 2C 0 F 2 B C 1 32 32 36 36 39 34 0
As37 MCB: Received response
As37 MCB: Response CBK-Client-Num 2 11 12, addr 1-226694
Async37 PPP: O MCB Ack(3) id 45 len 15
Async37 MCB: O 3 2D 0 F 2 B C 1 32 32 36 36 39 34 0
As37 MCB: O Ack Id 45 Callback Type Client-Num delay 12
As37 MCB: Negotiated MCB with peer
As37 MCB: Newstate 2-WAIT_RESPONSE -> 3-WAIT_TERMINATE
As37 LCP: I TERMREQ [Open] id 3 len 16 (0x32F108D4003CCD7400000000)
As37 LCP: O TERMACK [Open] id 3 len 4
As37 MCB: Peer terminating the link
As37 MCB: Newstate 3-WAIT_TERMINATE -> 5-WAIT_LINKDOWN
As37 CCP: State is Closed
As37 CCP: Compression already closed
As37 MCB: Link terminated by peer, Callback Needed
As37 MCB: Newstate 5-WAIT_LINKDOWN -> 6-CALLING
As37 MCB: Initiate Callback for ¦í-ÿÀ]þô at 226694 using Async DDR
As37 MCB: Dialer callback started
As37 PPP: Phase is TERMINATING
RADIUS: Send to unknown id 238 212.56.194.129:1646, Accounting-Request, len 186
RADIUS: authenticator 31 47 1C CC 12 25 99 5F - B4 A6 B7 C7 74 E6 29 84
RADIUS: Acct-Session-Time [46] 6 2
RADIUS: Acct-Input-Octets [42] 6 37
RADIUS: Acct-Output-Octets [43] 6 27
RADIUS: Acct-Input-Packets [47] 6 2
RADIUS: Acct-Output-Packets [48] 6 2
RADIUS: Acct-Terminate-Cause[49] 6 user-request [1]
RADIUS: Acct-Status-Type [40] 6 Stop [2]
RADIUS: Event-Timestamp [55] 6 1025017396
RADIUS: Received from id 238 212.56.194.129:1646, Accounting-response, len 20
RADIUS: authenticator 00 62 A3 3F 3A 4A E4 91 - 22 60 06 A6 65 15 1B A0
ANALOG_MODEM_CONNECTED: MODEM_DISCONNECTED at slot 1, port 4
Modem 1/4 CSM: CSM_MODEM_DEALLOCATE: modem is deallocated
Modem 1/4 Mcom: in modem state 'Disconnecting'
Modem 1/4 Mcom: DISCONNECT, duration = 00:00:06, reason (0xE) Remote Link Disc
TTY37: DSR was dropped
tty37: Modem: READY->(unknown)
Modem 1/4 Mcom: in modem state 'Idle'
TTY37: dropping DTR, hanging up
TTY37: Async Int reset: Dropping DTR
tty37: Modem: HANGUP->(unknown)
As37 LCP: TIMEout: State TERMsent
As37 LCP: State is Closed
As37 PPP: Phase is DOWN
TTY37: cleanup pending. Delaying DTR
%LINK-5-CHANGED: Interface Async37, changed state to reset
Modem 1/4 Mcom: switching to character mode
TTY37: destroy timer type 0
TTY37: no timer type 3 to destroy
TTY37: no timer type 4 to destroy
TTY37: destroy timer type 2
Async37: allowing modem_process to continue hangup
TTY37: restoring DTR
TTY37: autoconfigure probe started
%LINK-3-UPDOWN: Interface Async37, changed state to down
%FR-5-DLCICHANGE: Interface Serial0/0 - DLCI 580 state changed to INACTIVE
%LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0.580, changed state to down
CHAT37: Attempting async line dialer script
CHAT37: no matching chat script found for 226694
CHAT37: Dialing using Modem script: d0efault-d0ials0cript & System script: none
CHAT37: process started
CHAT37: Asserting DTR
CHAT37: Chat script d0efault-d0ials0cript started
CHAT37: Sending string: ATZ
CHAT37: Expecting string: OK
CHAT37: Completed match for expect: OK
CHAT37: Sending string: ATDT\T<226694>
CHAT37: Expecting string: CONNECT
Modem 1/4 Mcom: CONNECT at 28800/24000(Tx/Rx), V34, LAPM, V42bis, Originate
CHAT37: Completed match for expect: CONNECT
CHAT37: Chat script d0efault-d0ials0cript finished, status = Success
As37 LCP: I CONFREQ [Closed] id 1 len 20
As37 LCP: MagicNumber 0x6A201FD0 (0x05066A201FD0)
As37 PPP: Treating connection as a callout
As37 PPP: Phase is ESTABLISHING, Active Open
As37 AAA/AUTHOR/LCP: Authorization succeeds trivially
As37 LCP: O CONFREQ [Closed] id 72 len 25
As37 LCP: MagicNumber 0x15596A45 (0x050615596A45)
As37 LCP: O CONFACK [REQsent] id 1 len 20
As37 LCP: I CONFACK [ACKsent] id 72 len 25
As37 CHAP: O CHALLENGE id 29 len 24 from "bnm"
As37 LCP: I IDENTIFY [Open] id 2 len 18 magic 0x6A201FD0 MSRASV5.00
As37 CHAP: I RESPONSE id 29 len 34 from ".rig.auto.nbm"
RADIUS/ENCODE(000004A9): acct_session_id: 1440
RADIUS(000004A9): sending
RADIUS: Send to unknown id 29 212.56.194.129:1645, Access-Request, len 91
RADIUS: authenticator 59 01 FF FA 74 23 49 41 - BD 93 B9 1D DD D0 4B C3
RADIUS: Received from id 29 212.56.194.129:1645, Access-Accept, len 136
RADIUS: authenticator A0 6E A1 63 54 CC 42 D3 - 08 03 7B BE 12 AB 40 84
RADIUS: Received from id 4A9
As37 CHAP: O SUCCESS id 29 len 4
As37 PPP: Phase is UP
As37 AAA/AUTHOR/IPCP: FSM authorization not needed
As37 AAA/AUTHOR/FSM: We can start IPCP
As37 IPCP: O CONFREQ [Closed] id 21 len 16
As37 IPCP: CompressType VJ 15 slots (0x0206002D0F00)
As37 IPCP: Address 172.16.0.247 (0x0306AC1000F7)
As37 AAA/AUTHOR/CCP: FSM authorization not needed
As37 AAA/AUTHOR/FSM: We can start CCP
As37 CCP: O CONFREQ [Closed] id 20 len 10
As37 CCP: MS-PPC supported bits 0x00000001 (0x120600000001)
RADIUS/ENCODE(000004A9): Unsupported AAA attribute start_time
RADIUS/ENCODE(000004A9): Unsupported AAA attribute timezone
RADIUS: Send to unknown id 239 212.56.194.129:1646, Accounting-Request, len 135
RADIUS: authenticator E5 9D 09 D1 D1 18 B2 9B - F7 39 F6 04 0C D9 C3 7B
RADIUS: Acct-Session-Id [44] 10 "000005A0"
RADIUS: Event-Timestamp [55] 6 1025017449
RADIUS: Received from id 239 212.56.194.129:1646, Accounting-response, len 20
RADIUS: authenticator 60 68 BE D5 4B 6A 28 2A - 20 C7 EB DF 12 DD F9 31
As37 CCP: I CONFREQ [REQsent] id 3 len 10
As37 CCP: O CONFACK [REQsent] id 3 len 10
As37 IPCP: I CONFREQ [REQsent] id 4 len 40
As37 IPCP: CompressType VJ 15 slots CompressSlotID (0x0206002D0F01)
As37 IPCP: Address 0.0.0.0 (0x030600000000)
As37 IPCP: PrimaryDNS 0.0.0.0 (0x810600000000)
As37 IPCP: PrimaryWINS 0.0.0.0 (0x820600000000)
As37 IPCP: SecondaryDNS 0.0.0.0 (0x830600000000)
As37 IPCP: SecondaryWINS 0.0.0.0 (0x840600000000)
As37 AAA/AUTHOR/IPCP: Start. Her address 0.0.0.0, we want 0.0.0.0
As37 AAA/AUTHOR/IPCP: Processing AV addr
As37 AAA/AUTHOR/IPCP: Processing AV inacl
As37 AAA/AUTHOR/IPCP: Processing AV dns-servers
As37 AAA/AUTHOR/IPCP: Authorization succeeded
As37 AAA/AUTHOR/IPCP: Done. Her address 0.0.0.0, we want 192.168.5.7
As37 AAA/AUTHOR/IPCP: primary dns server 192.168.0.1
As37 AAA/AUTHOR/IPCP: no author-info for primary wins
As37 AAA/AUTHOR/IPCP: no author-info for seconday wins
As37 IPCP: O CONFREJ [REQsent] id 4 len 22
As37 IPCP: I CONFACK [REQsent] id 21 len 16
As37 CCP: I CONFACK [ACKsent] id 20 len 10
As37 CCP: State is Open
As37 CCP: ppp_hwcomp_open: no h/w
As37 IPCP: I CONFREQ [ACKrcvd] id 5 len 22
As37 IPCP: O CONFNAK [ACKrcvd] id 5 len 16
As37 IPCP: Address 192.168.5.7 (0x0306C0A80507)
As37 IPCP: PrimaryDNS 192.168.0.1 (0x8106C0A80001)
As37 IPCP: I CONFREQ [ACKrcvd] id 6 len 22
As37 IPCP: O CONFACK [ACKrcvd] id 6 len 22
As37 IPCP: State is Open
AAA/AUTHOR: Processing PerUser AV inacl
As37 IPCP: Install route to 192.168.5.7
As37 IPCP: Add link info for cef entry 192.168.5.7
%LINEPROTO-5-UPDOWN: Line protocol on Interface Async37, changed state to up
As37 LCP: I TERMREQ [Open] id 7 len 16 (0x6A201FD0003CCD7400000000)
As37 LCP: O TERMACK [Open] id 7 len 4
As37 IPCP: Remove link info for cef entry 192.168.5.7
As37 IPCP: State is Closed
As37 IPCP: Remove route to 192.168.5.7
RADIUS: Send to unknown id 240 212.56.194.129:1646, Accounting-Request, len 192
RADIUS: authenticator E5 F2 4C 28 8A 37 EE 17 - 08 0C B3 FF B6 DE 09 B2
RADIUS: Acct-Session-Time [46] 6 13
RADIUS: Acct-Input-Octets [42] 6 604
RADIUS: Acct-Output-Octets [43] 6 128
RADIUS: Acct-Input-Packets [47] 6 17
RADIUS: Acct-Output-Packets [48] 6 7
RADIUS: Event-Timestamp [55] 6 1025017461
RADIUS: Received from id 240 212.56.194.129:1646, Accounting-response, len 20
RADIUS: authenticator CC 9A F8 A5 01 DF 08 12 - 71 7C D2 AC A7 25 FA 39
Modem 1/4 Mcom: DISCONNECT, duration = 00:00:16, reason (0xE) Remote Link Disc
%LINEPROTO-5-UPDOWN: Line protocol on Interface Async37, changed state to down
End first debug listing ==================================================================================
Start second debug listing ==================================================================================
TTY37: DSR came up
As37 LCP: MagicNumber 0x45C67C58 (0x050645C67C58)
As37 LCP: O CONFREQ [Listen] id 73 len 25
As37 LCP: MagicNumber 0x15628EEE (0x050615628EEE)
As37 LCP: I CONFACK [ACKsent] id 73 len 25
As37 MCB: Flush
As37 CHAP: O CHALLENGE id 30 len 24 from "bnm"
As37 LCP: I IDENTIFY [Open] id 2 len 18 magic 0x45C67C58 MSRASV5.00
As37 CHAP: I RESPONSE id 30 len 34 from ".rig.auto.nbm"
RADIUS/ENCODE(000004AA): acct_session_id: 1442
RADIUS(000004AA): sending
RADIUS: Send to unknown id 30 212.56.194.129:1645, Access-Request, len 91
RADIUS: authenticator 82 44 82 E2 53 E5 B0 70 - BD 93 B9 1D 0E 77 C8 D9
RADIUS: Received from id 30 212.56.194.129:1645, Access-Accept, len 136
RADIUS: authenticator 69 30 73 9E 34 A6 DF F4 - 30 35 CB 02 42 15 97 79
RADIUS: Received from id 4AA
As37 CHAP: O SUCCESS id 30 len 4
As37 MCB: Start
Async37 PPP: O MCB Request(1) id 46 len 9
Async37 MCB: O 1 2E 0 9 2 5 0 1 0
As37 MCB: O Request Id 46 Callback Type Client-Num delay 0
RADIUS/ENCODE(000004AA): Unsupported AAA attribute start_time
RADIUS/ENCODE(000004AA): Unsupported AAA attribute timezone
RADIUS: Send to unknown id 241 212.56.194.129:1646, Accounting-Request, len 135
RADIUS: authenticator 86 A2 5B 28 FB F9 2F 72 - FF 7D 48 9A 88 3E 89 8B
RADIUS: Acct-Session-Id [44] 10 "000005A2"
RADIUS: Event-Timestamp [55] 6 1025018048
RADIUS: Received from id 241 212.56.194.129:1646, Accounting-response, len 20
RADIUS: authenticator 10 44 12 F6 5A 8B 0B D7 - 0D 19 64 5A 5B E2 9D 84
As37 MCB: Timeout in state WAIT_RESPONSE sending new Request 2
Async37 PPP: O MCB Request(1) id 47 len 9
Async37 MCB: O 1 2F 0 9 2 5 0 1 0
As37 MCB: O Request Id 47 Callback Type Client-Num delay 0
As37 MCB: Timeout in state WAIT_RESPONSE sending new Request 3
Async37 PPP: O MCB Request(1) id 48 len 9
Async37 MCB: O 1 30 0 9 2 5 0 1 0
As37 MCB: O Request Id 48 Callback Type Client-Num delay 0
As37 MCB: Timeout in state WAIT_RESPONSE sending new Request 4
Async37 PPP: O MCB Request(1) id 49 len 9
Async37 MCB: O 1 31 0 9 2 5 0 1 0
As37 MCB: O Request Id 49 Callback Type Client-Num delay 0
Async37 PPP: I MCB Response(2) id 49 len 6
Async37 MCB: I 2 31 0 6 1 2
As37 MCB: Response CBK-None 1 2
As37 MCB: Resp with None type, Expected Client-Num type
As37 MCB: Shutdown
As37 MCB: Flush
RADIUS: Send to unknown id 242 212.56.194.129:1646, Accounting-Request, len 186
RADIUS: authenticator A5 74 83 05 E6 CE C8 C4 - F3 4B FE 6C 0B AA 7F 84
RADIUS: Acct-Session-Time [46] 6 7
RADIUS: Acct-Input-Octets [42] 6 8
RADIUS: Acct-Output-Octets [43] 6 39
RADIUS: Acct-Output-Packets [48] 6 3
RADIUS: Acct-Terminate-Cause[49] 6 lost-carrier [2]
RADIUS: Event-Timestamp [55] 6 1025018055
RADIUS: Received from id 242 212.56.194.129:1646, Accounting-response, len 20
RADIUS: authenticator F0 6D A9 8D F8 7E 82 78 - C7 19 A1 1D BB A6 08 FB
Modem 1/4 Mcom: DISCONNECT, duration = 00:00:11, reason (0x9) DTR Drop
End second debug listing ==================================================================================
06-25-2002 08:48 AM
IOS will always create the "chat-script modem-callback" when callbcak is initiated by the callback server to communicate between ios and modem.
Now if you do not want to get called back (by clicking cancel or escape) and wants to login straight in, use "ppp callback permit" under the "interface group-async 1"...It will allow callback if you want to..Thanks..Tejal
06-25-2002 10:06 PM
Thanks, now it is work fine.
