Problem in "Show mls entry"
I am using a Cat 5000 with cat5000-sup3.5-5-14.bin. I configured MLS using the Cat 5000 and a Cisco 3620 rotuer.
However the output of "show mls entry" for Destination IP mode did not show any information in "last used Source IP address" and "last used protocol and ports".
(Similar, for Source-Destination IP mode, no information for "last used protocol and ports" is shown.)
Plz help.
Thanks.
Norman
Silver
Re: Problem in "Show mls entry"
Make sure you have met all the system requirements to implement MLS.
http://www.cisco.com/warp/public/473/55.html
All requirements are met. Both switch and router recognised each other in MLS.
All seems working. The "show ip mls" displays all MLS entries except there is nothing shown in the "lasted used" columns.
105
