Problem in Starting 2950
When i start to configured our Cisco 2950 Switch through Consol Cable , is display me this message and rebot again,
File "flash:/c2950-i6q4l2-mz.121-22.EA6.bin" uncompressed and installed, entry p
oint: 0x80010000
executing...
Error: hardware not supported by firmware.
Try loading newer software instead.
System Resetting...
Re: Problem in Starting 2950
Are your trying to upgrade Cisco 2950 switch or Cisco 2950 LRE type?
Because the latter model doesnt support the ios file code which you are trying out here.
regds
I just delete the previous config.text file from the Flash memory, and copy the new one to the flash from the TFTP server, when i restart the switch the above error genrated, due to this error, switch is start display the error and restart again, what is the solution of this problem,
How can i solve this problem, Give me a solution.
Thank You
144
