You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
problem installation Cisco Works CD one 4th edition
I have a problem to install the first CD of my Cisco Works 2000 .
I have a W2k Professional with SP 2 . All the requirements of the installation guide are fulfilled . But if i will start the application there is now ICON to start the desktop .
Any solution for this problem ?
  • Other Network Infrastructure Subjects
1 ACCEPTED SOLUTION
Re: problem installation Cisco Works CD one 4th edition
I do not fully understand your problem. You mentioned 'no icon to start the desktop'?
If you are trying to launch CW2000 simply start your browser and put in your servers hostname/IP followed by the port number for CW2000 (1741).
Ex. http://yourservername:1741 and this will launch CW2000 (for IE make sure Java VM is enabled)
This is a good starting page for CW2000 its links to everything.
http://cisco.com/warp/public/44/jump/ciscoworks.shtml
1 REPLY
82
