Problem installing CW2000 CD 1
I'm installing CW2000 CD 1 for NT 4, but the system is giving an error "cannot create the install dependency file" then stops from there...what does it mean...
Blue
Re: Problem installing CW2000 CD 1
What is the version of CD-One?. Is it 2nd, 3rd or 4th Edition?. What Service Pack is installed on NT?. Is this a Pentium-4 server?
the CD 1 version is 2nd edition, its pentium 4 server with service pack 6 installed..
thanks....
Blue
This is due to CSCdt26215. You can look at the details via CCO Bug Toolkit. It's fixed now, upgrade to the latest CD-One 5th Edition.
thanks for the info...where can i get CD-One 5th Edition?...is this available on cisco software center?
Blue
sir, if I will install the CD-One 5th edition, is there any problem with the other application like Device Manager and Resource manager essentials. Thanks
Blue
No, because you're get the latest versions of DFM, RME with the 5th Ed bundle which works fine with it.
sir, can you please give me the part number of the CD -One 5th Edition. because i'm having hard time to locate the correct part No.........thanks
Blue
sir, can I order ony CD-One 5th edition without CM, RME....
thanks
Blue
No.
sir, can we order the upgrade software CWLMS-2.1-UP-K9, please note that we need to make new installation on a pentium 4 machine. we have CWLMS 1.0 - NT4. its working fine on pentium III machine...thanks
Blue
135
