11-18-2003 06:22 AM - edited 03-02-2019 11:47 AM
I am currently running Ngenius ver. 1.4 SP8.
When I try to add a 3548XL in nGenius I get the following warning : "Write community is incorrect."
From the progress tab I see:
Learn Protocols OK
Learn Interfaces OK
Update Database OK
Install Global Settings Error
Install Templates Error
Learn Roving OK
Discover Capabilities OK
The write community is correctly configured on the switches... The problem apears only on 3548XL devices.
Thx!
11-18-2003 12:09 PM
Are you tring to add this switch using Automatic as the device type?. If so, then try using the correct relevant device model from the list instead of Automatic to see if that works, assuming that the RW strings are indeed correct.
11-18-2003 12:46 PM
I tried using 3500XL and 3548XL types instead of automatic type... still no luck !
