Community Member
Problem logging ACL deny's to buffer and syslog
I am trying to log messages that match the deny ip any any statement at the end of my access list to buffer and syslog. Neither is working on this switch, though I have gotten it to work on another switch. Am I doing something wrong or is this a bug? The relevant information:
4507, Sup V
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I5K91S-M), Version 12.2(25)EWA5, RELEASE SOFTWARE (fc1)
interface Vlan209
description IPT NETWORK
ip address
ip access-group PhonesIn in
ip access-group PhonesOut out
ip helper-address
Extended IP access list PhonesIn
350 permit ip host any (74 matches)
360 deny ip any any log (123 matches)
Extended IP access list PhonesOut
340 permit ip any host
350 deny ip any any log (177 matches)
Switch# show logging
Syslog logging: enabled (0 messages dropped, 129 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
Console logging: disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 45020 messages logged, xml disabled,
filtering disabled
Exception Logging: size (8192 bytes)
Count and timestamp logging messages: disabled
Trap logging: level informational, 44129 message lines logged
Logging to, 44129 message lines logged, xml disabled,
filtering disabled
Re: Problem logging ACL deny's to buffer and syslog
The following example gives you an idea
access-list vlan30 extended permit
access-list vlan30 extended deny ip any any
deny ip any any as the implicit deny should take care of this.
Hall of Fame Super Gold
I am puzzled about this answer since the original post was about not getting the output to logging to syslog or logging to buffered.
The output of show log looks like things should work. It does show that logging is configured to a syslog server and it does show that logging to the buffer is enabled and that the logging level of the buffer should include the ACL deny messages.
Can the original poster clarify whether other things are logging correctly to syslog and buffer and it is only the ACL deny that is not showing up or are there issues with logging other things as well?
It might be helpful in understanding what is going on if the original poster would post the output of this command:
show run | include log
