problem of 3661+n30dm+nm1ce1u
the system has been stable more than 1 year,last week,a sudden power-off happened,after some users can't dial in,the error is like "618 error","619 error","can't open port",but many other users can dial in(include ourself) and last a long time (1hour),even re-install a new modem,the computer also can't dial in,could u tell me the reason?
sho modem:everything is ok
sho ver:c3660-is-mz-123.1a.bin
and even I debug ppp neg,debug ppp authen,debug dialer,nothing will apper in the console screen when the failed-dialer-in user dialer in,just can see"xxxxxx is connected to interface XXX,
isdn-6-disconnect:disconnect to xxxxx"
the current configuration is :
Current configuration : 17488 bytes
version 12.3
no parser cache
service timestamps debug uptime
service timestamps log uptime
hostname smbc3661
enable secret xxxxxx
enable password xxxxx
username xxxxxxpassword xxxx
memory-size iomem 15
modem country mica china
ip subnet-zero
no ip domain lookup
isdn switch-type primary-net5
no voice hpi capture buffer
no voice hpi capture destination
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-31
interface FastEthernet0/0
ip address x.x.x.x 255.255.255.0
ip access-group 123 in
duplex auto
speed auto
interface Serial1/0:15
no ip address
encapsulation ppp
dialer pool-member 1
isdn incoming-voice modem
ppp authentication pap chap callin
interface Group-Async1
ip unnumbered FastEthernet0/0
encapsulation ppp
load-interval 30
dialer in-band
async mode dedicated
peer default ip address pool 3661
no keepalive
group-range 65 94
hold-queue 10 in
interface Dialer1
encapsulation ppp
dialer pool 1
dialer idle-timeout 3600
dialer-group 1
no cdp enable
router rip
version 2
network 168.168.0.0
ip local pool cisco3661-group-1 x.x.x.x 168.168.44.140
ip local pool 3661 x.x.x.x 168.168.45.150
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 168.168.45.2
ip route x.x.x.x x.255.255.0 168.168.45.2
access-list 1 permit any
access-list 123 deny tcp any host x.x.44.55 eq ftp log
access-list 123 deny tcp any hostx.x.44.55 eq www log
access-list 123 permit ip any any
dialer-list 1 protocol ip list 1
line con 0
line 65 94
exec-timeout 0 0
flush-at-activation
modem answer-timeout 120
modem Dialin
modem autoconfigure discovery
transport input all
autoselect ppp
flowcontrol hardware
line aux 0
line vty 0 4
password passwordxxx
login
end
smbc3661#
Silver
Re: problem of 3661+n30dm+nm1ce1u
Do we even see the call hit the 3660 when the failed user dials in? Also ensure we have modems free to take any additional calls.
deb isdn q931/ deb modem / deb modem csm / deb ppp nego for a user that fails will be useful.
Thanks,Mak.
yes,we can see "xxxxxx(telephone number) connected to serial 1/0:12",then "xxxxxx disconnected from serial 1/0:12",but even I debug ppp nego,debug ppp authen,debug dialer,I can't see anything else,next time I will try to debug isdn q931,debug modem.
and another problem is after I dial in ,I only can ping the inside host no more than 1 minute,but still connecting with the 3661,in 3661,I show user and still can see the user is connected in the 3661(the idle-time I config is 1 hour)
74
