Community Member
problem of dial from aux,please help!!!
router2600---aux----modem(datacraft 3296H)
cisco2600#sh int async 65
Async65 is up (spoofing), line protocol is up (spoofing)
cisco2600#sh line 65
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
* 65 AUX 38400/38400 - inout - - - 0 0 0/15049 -
Ready
Line 65, Location: "", Type: ""
Length: 24 lines, Width: 80 columns
Baud rate (TX/RX) is 38400/38400, no parity, 1 stopbits, 8 databits
Status: Ready, Active, No Exit Banner, CTS Raised, Modem Signals Polled
Capabilities: Modem Callout, Modem RI is CD, Modem Autoconfigure
Modem state: Ready
Modem hardware state: CTS* DSR* DTR RTS
TTY NUMBER 65
Parity Error = 0 Framing Error = 45 Receive Error = 45 Overrun = 0
Outcount = 0 totalout = 34024 incount = 0 totalin = 24819
Special Chars: Escape Hold Stop Start Disconnect Activation
^^x none - - none
Timeouts: Idle EXEC Idle Session Modem Answer Session Dispatch
never never none not set
Idle Session Disconnect Warning
never
Login-sequence User Response
00:00:30
Autoselect Initial Wait
not set
Modem type is MY_MODEM.
Session limit is not set.
Time since activation: 00:01:47
Editing is enabled.
History is enabled, history size is 10.
DNS resolution in show commands is enabled
Full user help is disabled
Allowed transports are pad v120 telnet rlogin. Preferred is telnet.
No output characters are padded
No special data dispatching characters
cisco2600#
cisco2600#sh debug
General OS:
Modem control/process activation debugging is on
Dial on demand:
Dial on demand events debugging is on
cisco2600#ping 1.1.1.1
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
00:12:56: As65 DDR: Dialing cause ip (s=90.1.1.1, d=1.1.1.1)
00:12:56: As65 DDR: Attempting to dial 852
00:12:56: CHAT65: Attempting async line dialer script
00:12:56: CHAT65: dial attempt to 852 and line is in use
00:12:56: As65 DDR: Unable to dial 852......
Success rate is 0 percent (0/5)
cisco2600#clear line 65
[confirm]y [OK]
cisco2600#
00:13:26: TTY65: Line reset by "Exec"
00:13:26: TTY65: Modem: (unknown)->HANGUP
00:13:26: TTY65: no timer type 0 to destroy
00:13:26: TTY65: destroy timer type 1
00:13:26: TTY65: no timer type 3 to destroy
00:13:26: TTY65: no timer type 4 to destroy
00:13:26: TTY65: no timer type 2 to destroy
00:13:27: TTY65: dropping DTR, hanging up
00:13:27: TTY65: Set DTR to 0
00:13:27: tty65: Modem: HANGUP->IDLEclear line 6
00:13:29: TTY65: restoring DTR
00:13:29: TTY65: Set DTR to 1
00:13:30: TTY65: DSR came up
00:13:30: tty65: Modem: IDLE->(unknown)
00:13:30: TTY65: EXEC creation
00:13:30: TTY65: create timer type 1,
cisco2600#
00:13:35: As65 DDR: Dialing cause ip (s=90.1.1.1, d=1.1.1.1)
00:13:35: As65 DDR: Attempting to dial 852
00:13:35: CHAT65: Attempting async line dialer script
00:13:35: CHAT65: dial attempt to 852 and line is in use
00:13:35: As65 DDR: Unable to dial 852......
cisco2600#
00:13:50: As65 DDR: re-enable timeout
router config is:
modemcap entry MY_MODEM:MSC=&F1S0=1
interface Async65
ip address 90.1.1.1 255.255.255.0
encapsulation ppp
dialer in-band
dialer idle-timeout 900
dialer string 852
dialer-group 1
ip route 0.0.0.0 0.0.0.0 Async65
line aux 0
exec-timeout 0 0
modem InOut
modem autoconfigure my_modem
transport input all
stopbits 1
speed 38400
1 REPLY
Community Member
Re: problem of dial from aux,please help!!!
I found DDR will work if I ping 1.1.1.1 at middle of "clear line 65",I don't know why.
[confirm]y [OK]
00:28:31: TTY65: Line reset by "Exec"
00:28:31: TTY65: Modem: (unknown)->HANGUP
00:28:31: TTY65: no timer type 0 to destroy
00:28:31: TTY65: no timer type 1 to destroy
00:28:31: TTY65: no timer type 3 to destroy
00:28:31: TTY65: no timer type 4 to destroy
00:28:31: TTY65: no timer type 2 to destroy
00:28:31: TTY65: dropping DTR, hanging up
00:28:31: TTY65: Set DTR to 0
00:28:31: tty65: Modem: HANGUP->(unknown)
00:28:31: TTY65: cleanup pending.
ping 1.1.1.1
00:28:33: TTY65: restoring DTR
00:28:33: TTY65: Set DTR to 1
00:28:34: As65 DDR: Dialing cause ip (s=90.1.1.1, d=1.1.1.1)
00:28:34: As65 DDR: Attempting to dial 293
00:28:34: CHAT65: Attempting async line dialer script
00:28:34: CHAT65: no matching chat script found for 293
00:28:34: CHAT65: Dialing using Modem script: d0efault-d0ials0cript & System scr
ipt: none
00:28:34: CHAT65: process started
00:28:34: CHAT65: Asserting DTR
00:28:34: TTY65: Set DTR to 1
00:28:34: CHAT65: Chat script d0efault-d0ials0cript started.....
cisco2600#
132
