11-26-2002 10:49 PM - edited 03-02-2019 03:12 AM
My configurations are as follows:
line 2
speed 9600
modem inout.
flowcontrol software
When I did a reverse telnet onto the AS2511-RJ, I got a connection refused.
The port I was using is 2002
I do not know why it did not work.
Anybody PLEASE HELP !!!!!!
Kelvin
11-27-2002 07:33 AM
Kelvin,
Try the command "transport input all" in line configuration mode. Good luck.
Mark
11-27-2002 09:12 AM
Also make sure that the line is not in use..type "sh line" and make sure that there is no " * " in front of line 2. If there is, the line is in use so you need to use "clear line 2" to clear it and then reverse telnet.
