Problem on a Reverse Telnet on AS2511-RJ
My configurations are as follows:
line 2
speed 9600
modem inout.
flowcontrol software
When I did a reverse telnet onto the AS2511-RJ, I got a connection refused.
The port I was using is 2002
I do not know why it did not work.
Anybody PLEASE HELP !!!!!!
Kelvin
Bronze
Re: Problem on a Reverse Telnet on AS2511-RJ
Kelvin,
Try the command "transport input all" in line configuration mode. Good luck.
Mark
Also make sure that the line is not in use..type "sh line" and make sure that there is no " * " in front of line 2. If there is, the line is in use so you need to use "clear line 2" to clear it and then reverse telnet.
172
