problem on the 7507 mib
yesterday we use the snmpget comand to get the flux for a subinterface on 7507, but the number we get is too large ,it is not equal to the statistics we see useing the "show int " .
when we reboot the 7507 ,the symptom disappeared.
I want to know what happened ,is something wrong with the 7507 ?
1 REPLY
Bronze
Re: problem on the 7507 mib
If the problem happens again, don't reboot. Instead, call TAC and have them advise you. You could check your IOS against bug toolkit to see if there is an open issue as well.
98
