rk
Problem saving config on C2600
After making a few changes on a C2600 router I'm not able to wr it to the NVRAM. It gives the following error message:
"% Configuration buffer full, can't add command:........Aborting save"
Any clues? and work around?
Silver
Re: Problem saving config on C2600
You can try this:
Use "service compress-config".
Before doing this save your config into your flash using:
copy running flash:myConfig
Do 'dir' to confirm your config is written to flash.
Hope this helps.
rk
Thanks. I'll try it.
Bronze
Not the same error message I remember but I ran into a problem when my config go too big for nvram. Try adding "service compress-config" in global config mode and see if it will save after that.
rk
109
