Problem using NM-4B S/T concurrently with PPP multilink
I am configure the 4 ports ISDN NM as a backup link of frame-relay in cisco 2610 router. Once the frame-relay disconnect, i need to bring up the four line together due of heavy traffic. Problem is, if one of the port get down or one of the line not active, then the remain ISDN port will not be activate as well.
Eg : If line of port 2 fail, then the router will able to bring up the line at port 3 only. The router will keep trying to bring up the port 2. It will hit error and stop there.
1 REPLY
Bronze
Re: Problem using NM-4B S/T concurrently with PPP multilink
You can try couple of things. Use some debug commands like 'deb ppp auth', 'deb ppp neg', 'deb isdn q931' which will throw more light on what is happening and creating the problem. Also, you can check whether there are any known problems related to the hardware or software you are using.
88
