problem using squeeze command
I have a cisco 3660 (R527x) running C3660-JS-MZ_122-17.BIN image file.
I have deleted a file from flash
router#sh flash:
System flash directory:
File Length Name/status
1 12449664 c3660-js-mz.121-5.T4 [deleted]
2 13366336 C3660-JS-MZ_122-17.BIN
[25816128 bytes used, 7738304 available, 33554432 total]
32768K bytes of processor board System flash (Read/Write)
In order to release the memory space occupied by the deleted file, i enter the squeeze command. But i have an error message:
router#squeeze flash:
Squeeze operation may take a while. Continue? [confirm]
first create squeeze log by erasing the entire device
%Error squeezing flash (Unknown error 0)
Does someone know what this error message mean exactly? is there another way to release the memory space ocupied?
1 REPLY
Blue
Re: problem using squeeze command
The only way to recover from that is to do as it says; erase the flash and reload what you need. Not sure why this happens.
173
