01-09-2003 01:25 PM - edited 03-02-2019 04:04 AM
When inserting the gbic into the 2950, the switch freezes and all activity stops.
when ejecting the gbic the switch continues operating.
In the log the following is displayed.
00:06:05: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, ch
anged state to down
00:06:34: %GBIC-4-XCVR_INTERR: Internal error occurred in setup for GBIC interfa
ce Gi0/1
00:06:34: %GBIC-4-CHECK_SUM_FAILED: GBIC EEPROM data check sum failed for GBIC i
nterface Gi0/1
00:06:34: %GBIC-4-UNRECOGNIZED_EXTTYPE: GBIC interface Gi0/1 has unrecognized ex
tended type
00:06:34: pm assert failure: pd->operInfo.operErrReason == pm_port_errdisable_no
ne: ../switch/pm/pm_errdisable.c: 91: pm_port_set_errdisable
00:06:34: -Traceback= 80329534 8036DB24 8031930C 80319794 80372398 80372BA0 801C
3CFC 801C3CE8
00:06:34: %PM-4-ERR_DISABLE: gbic-invalid error detected on Gi0/1, putting Gi0/1
in err-disable state
00:06:34: calhoun_add_gbic_module_to_entity_mib_phyTable: (2) error reading GBIC
module on Gi0/1
Newest IOS image found have been tried without luck. (c2950-i6q4l2-mz.121-12c.EA1.bin)
There is no config of the port, default setting is used.
Is there a bug, or is it somting else.
Jan
01-09-2003 05:02 PM
What kind of copper GBIC is this? If it is WS-G5482, it is not supported in a CAT2950
http://www.cisco.com/univercd/cc/td/doc/product/lan/c2900xl/1000gbic/1000comp.htm#67270
WS-G5483 are supported in the 2950's
03-03-2003 01:14 AM
Hey Jan,
I have the same problem with WS-G5484 (1000BaseSX) modules. cannot seem to solve it out.
Did you solve the problem?
Henry
04-10-2003 04:13 AM
Hi Jan,
I have the same issue on 2950 with WS5484 Gbic (1000SX). In version 12.1.6EA2, it is working perfectly well but upgrading to version 12.1.12 or 12.1.13 (latest ones), the same Gbic gave me the same errror message as you. I have opened a TAC case, and it seems that the Gbics are not recognized so you have to change it (RMA). Not all the Gbics are provoking this error, so you have to find one which is recognized with the newest IOS version.
What the Gbic serial number looks like ? It seems that with the serial number and the part number written on the Gbics, you can know if this is a good one or not.
Cheers,
./Rémi
