problem with a priotrity list
I have a router 2620 and i want to give him some priority on some flow. So i decide to use the priority-list command, but that don't seem to be good.
I try to use a netmeeting between 2 compueter. For see if it's work i launch a some ftp for test if the priority list make his job.
This is my command tha i enter:
(config)#priority-list 1 protocol ip hight udp 7648
(config)#priority-list 1 protocol ip hight udp 24032
(config)#priority-list 1 protocol ip hight udp 56800
(config)#priority-list 1 protocol ip low tcp 21
(config)#priority-list 1 default normal
(config)#int fast 0/1
(config-if)#priority-group 1
I don't know why but the netmeetin lag, and i think that the priority list doesn't work
So i try the commande
#debug priority
And nothing go on my screen
Thanks for your answer
Bronze
Re: problem with a priotrity list
Is there only one router or is there another one on the ohter side of a wan link? Did you set priority there too?
Oups i forgot, yes there is another one on the other side, this is the same router (2620) and i set the same priority on the 2 router.
I set priority on the interfaces which establishes the link between the 2 routers
88
