Community Member
Problem with access between cisco 2600 with PRI module and clientes with TA
I have a cisco 2600 with Network Module 2 PRI interfaces. I will receive routers ISDN clients and TA clients. When i connect a remote client with TA, client login successfully but when windows "prompt registring host in network" connection give an error:733 of CP TCP/IP that say: your host and remote host dont agree about control protocols of PPP.
How to resolve Them.
Thanks.
1 REPLY
Bronze
Re: Problem with access between cisco 2600 with PRI module and c
If there is a quiet moment when no-one is connecting, turn on "debug ppp negotiation" and try to connect with a TA (then turn it off with "undebug all"). The resulting output should learn us more.
hth
Herbert
87
