Problem with ACL Manager ver 1.4
adelkarim
I have a CW2K server installed on a win2k sp2 machine. I have CD one, RME, CM, and DFM installed on same machine.
Once I install ACL manager ver 1.4 , I cannot access the page (Resource Manager Essentials > Administration > Job Approval > Edit Preferences).
Is this a well know bug or it's a problem with my server??
Thank you
Adel
You might see this problem, if you are using Netscape as your browser.
This particular screen doesnt come up in the java plugin but comes up
in the browser jvm.
There is a known problem with netscape, for this behavior.
This is due to VisiBroker 2.5, which is shipped with Netscape 4.x by default.
VisiBroker 2.5 classes are not compatible with VisiBroker 4.1 classes shipped with CiscoWorks2000
The workaround is to :
Delete the file iiop10.jar from the Netscape 4.x installation. This file is
located at Netscape Install Directory\Program\java\classes.
rmushtaq
Level 8
Level 8
What is the version of RME installed?. And what is the exact error message that you see when you do RME> Administration > Job Approval > Edit Preferences ?
in the browser jvm.
Any option for Netscape 7.x?
