Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Problem with ANIServer process in LMS 3.2
When I click in topology services the next message appears (View attachment)
What is the problem?
Best regards
1 REPLY
Re: Problem with ANIServer process in LMS 3.2
As per the error it says it is unable to find the hostname of the server through which it is connecting,can you check the hostname is added in DNS and you are aslo reachable to server via hostname.
Ganesh.H
252
