Webcast-Catalyst9k
problem with C10k boot
I have a problem with a C10k because I can't boot it for wrong or corrupt IOS file.
I can't break the boot for changing the boot configuration. I use the key "shift + break/pause" but this doesn't work.
Could anyone give me a suggestion to reach rommon level?
It it could be useful I attach the console boot view.
Thank you very much.
Regards.
Paolo
1 REPLY
Re: problem with C10k boot
Hi Paolo,
You need to use ' CTRL+BREAK " key in order to break into rommon. Once you are there you should be able to boot it.
Let me know if you face any problem.
regards,
-amit singh
114
