01-10-2012 05:33 PM - edited 03-03-2019 06:28 AM
There is a WS-C6504-E with Supervisor WS-SUP32-GE-3B and module WS-X6148A-GE-TX. It was necessary to clear the config, cleaned up "erase startup-config", rebooted the device. Network interfaces with a clean config to start his "shutdown". Unable to connect to the console. I tried with different cables and computers does not help. I tried to touch on the speed of the port did not help. Read somewhere that need to hold down the reset button on the front of the supervisor for 30 seconds. The device then restart, but not booted. If you are loading Indication "status", "system", "active" and "pwr mgmt" on the front panel flashes a few times with different colors and lights up in orange all. The remaining LED's and are extinct. Has anyone seen this?
01-10-2012 07:12 PM
Hi Nikolay,
These leds all together can mean basically few things - from HW problem to the Supervosr stuck in rommon. Thus I would try few things:
- physically reseat supervisor in the slot
- check that console cable, terminal working on other dvices
- try to console in once again
These are the leds meanings:
Nik
01-11-2012 01:36 AM
I tried, to no avail. I take flash card with a supervisor and watched its content from another device:
rommon 3 > dir flash:
program load complete, entry point: 0x8000f000, size: 0xcb80
Directory of flash:
2 47608836 -rw- s3223-ipservices_wan-mz.122-18.SXF12a.bin
This file is sufficient for normal boot?
Thank you!
01-11-2012 01:58 AM
Yeap the eimage looks fine, though it can be corrupted. You can try watching this flash on the other booted SUP and do "verify /md5" command to generate hash for it - then compare the hash for exactly same image on cisco.com. If does not match - then image is corrupted.
You can also try the SUP in question in the other chassis. I see you have some other SUP in ROMMON - so I guess you can swap those for testing.
Nik
01-12-2012 09:27 PM
Checked MD5, all right. But the device still does not work. Probably have to find a service center and other ideas I had not.
01-15-2012 12:11 AM
If the console working to one SUP and does not work to another. And the second SUP leds are amber - then possibly we gat HW problem. The other possiblity is that smth with console/terminal still and SUP trying to download not the image on PCMICA card but image on the internal bootflash on SP. If that image is bad it can fall to ROMMON back.
Posibbly you can try reseating the DRAMs and changing internal bootdisks to make sure image is good there.
NIk
01-15-2012 06:36 PM
I have a little experience, this can be done?
Thank you very much for your help!
01-15-2012 08:42 PM
Yeap - you can easily reseat memory yourself on the SUP. Following link can help to locate DIMMs on SUP32:
Nik
02-14-2012 10:47 PM
Nothing has helped. Sent to a service center. If repaired, I'll try to find the cause of the master and write here.
