You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Problem with CallBack nm-16am
I do this configuration on my router(2611) but callback does not work.please tell me why?
CAORAS#sh ru
Building configuration...
Current configuration : 3071 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname CAORAS
aaa new-model
aaa authentication login LOCAL local
aaa authentication ppp default none
aaa authentication ppp isputil group radius local
aaa authorization network default none
aaa authorization network isputil group radius local
aaa accounting update newinfo
aaa accounting network default none
aaa accounting network isputil start-stop group radius
aaa session-id common
enable secret xxxxxxxxxxx
enable password xxxxxxxxx
username admin password xxxxxxxxxxx
username abtahi callback-dialstring "" password xxxxxxxx
ip subnet-zero
no ip source-route
ip name-server 192.x.x.3
ip name-server 81.x.x.66
async-bootp dns-server 192.168.3.3 80.231.163.195
chat-script offhook "" "ATH1" ok
chat-script callback ABORT ERROR ABORT BUSY "" "ATZ" ok "ATDT \T"
timeout 60 co
nect \c
interface Ethernet0/0
ip address 192.168.3.4 255.255.255.0
ip nat outside
half-duplex
interface Ethernet0/1
ip address 192.168.0.9 255.255.255.248
ip access-group NAT in
ip nat inside
half-duplex
interface Async48
ip unnumbered Ethernet0/0
ip accounting output-packets
encapsulation ppp
ip tcp header-compression passive
no ip mroute-cache
load-interval 60
async mode interactive
peer default ip address pool DIALIN
no fair-queue
ppp max-bad-auth 3
ppp callback accept
ppp authentication chap pap
ip local pool DIALIN 192.168.3.200 192.168.3.216
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.3.3
ip http server
ip pim bidir-enable
snmp-server community xxxxx RW
radius-server host 192.168.3.2 auth-port 2228 acct-port 2229
radius-server retransmit 5
radius-server timeout 15
radius-server key xxxxxxxxxxx
line con 0
exec-timeout 0 0
password xxxxxxxxxxxxx
line 48
script modem-off-hook offhook
script callback callback
login authentication LOCAL
modem InOut
transport input all
autoselect during-login
autoselect ppp
callback forced-wait 10
line aux 0
line vty 0 4
end
  • Other Network Infrastructure Subjects
Re: Problem with CallBack nm-16am
We need more information. 1)who is dialin in with what kind of PC etc 2)how you want to configure callback 1) via router b) via AAA server. 3)Is PC configured properly for callback.
Now looking on the config you have posted, its not clear. You can visit following link for Configuring MS Callback via router Between a Router and a Windows PC
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a0080094338.shtml
So if that doesn't work, we need to see the following debug from router for a call and post it here
debug modem
debug ppp negotiation
debug aaa authentication
debug aaa authorization
debug ppp negotiations
debug ppp cbcp
debug callback
Also if you want callback using AAA server, visit
http://cco/en/US/products/sw/secursw/ps2086/products_configuration_example09186a008009404f.shtml
thanks about your help.I must to say that I want to configure only one of async port (example async 48) to accept callback from local user account on my router and reject all other incoming dial-in from AAA server.I want to use a Windows XP to dialin and my callback number must be asked before performing dialing proccess from router.
I have enabled my pc to accept callback but nothing happend.
thanks
As i have mentioned, we need to see the debugs when you dialin. So post the debugs for a call here.
If you want the router to ask you the callback number, use "ppp callback permit" on the interface.
As Tejal mentioned, we need to see the requested debugs to see why callback is not working.
~Zulfi
I've found my problem with debug commands and could solve it.My problem was about Authorization in AAA configuration after config it my callback worked.
Hi Ahmad
I saw your mail on the Cisco’s Discussion Forum site. You had problem with implementing callback at 2610. I have same problem with 3525 and NM-8AM v2. Would you please let me know how you solved the problem. Do you have any suggestion. I have heard about the same problem from some friends. Some of them changed the IOS and solved. Some of them couldn’t solve it. I have tried with IOS 12.3.4 (XD), 12.3.4 (XD1), 12.3.4 (XD3) and 12.3.7 (T2). No response. As you defined, when you remove ppp callback accept command, everything is fine connecting to the 3725.
If you have any suggestion about another topic I will be grateful. I am trying to connect Nokia30 GSM modem to the 3725 Asycn port. (NM-8A/S)
But I couldn’t .
Thanks.
You can use my email hulusi.turgut@servus.com.tr
Hi JMCNIERNEY
Did you get a result on the PPP Callback on your 3725.
I have a similar issue on a 3745 with Group Async interface and PRI. I have had various issues and each IOS has moved the fault along without fixing it.
Now IOS mz.123-10 Callback is offered to Users however will not dial back. Outgoing call is rejected. Have you had any success.
Many thanks
Larry_s
Silver
If you are seeing this issue on various IOS images then I will definitely want to try this out in my lab & maybe raise a bug if need be. Can you please post the running configuration (where the callback fails) & the sh ver.
1. Are you configured for callback thru AAA? If yes, can you try locally?
2. If this is MS callback, what is the OS on the PC?
3. If it’s a modem connected to Router as a callback client & 3745 as the callback server then like to know the modem make/ router make?
Thanks, Mak
149
