Problem with cisco2691 FastEthernet interface
I bought Cisco2691( IOS12.2(8), IDS,FW,MEM256 ) days before, and after five hours I set it up, it refused to work.
The configuration image is as follow:
eth0 192.168.2.1/24
eth1 192.168.3.1/24
Access-list is permit any with two interface ( in ).
Two clients are:
client0 192.168.2.2
client1 192.168.3.2
The problem is :
I can ping from 192.168.3.2 to 192.168.2.1 , but not 192.168.2.2
I can not ping from 192.168.2.2 to 192.168.2.1 too
with show arp , i can found client0's mac address in router's arp table,
but I can not found eth0's mac address in client0's arp table.
With show interface fastethernet0/0, not any errors,
With test interface fastethernet0/0, not any errors too.
I changed the client0 and the cable connected to eth0, but not worked.
Anyone can tell me what' the problem?
Re: Problem with cisco2691 FastEthernet interface
The problem looks like it is at the 192.168.2.2 end. Is the interface up? Is line protocol up? I'm sure the interface is up because it responds to a ping, but look anyway. Remember that an Ethernet link is four wire. It can be up at one end and down at the other. Check the IP configuration of client 192.168.2.2. (I will guess that it is a Windows client). Do winipcfg (or whatever variation is needed for your operating system). Is the TCP/IP stack loaded properly on the client ('ping localhost' from a command prompt)? Can the client ping itself (ping 192.168.2.2)? It may be an access list issue. Remove the access list and try it. Does it work without the access list?
When you can answer 'yes' to all of these questions it should work. Let us know what you find.
There is no problem in 192.168.2.2
With debug arp , I found 2691 sent req packet to 192.168.2.2 , but actually,
with netmonitor, 192.168.2.2 did not receive the req . But 192.168.2.1 can receive the req packet from 192.168.2.2 , and then put the mac of 192.168.2.2 to the arp table. I doubt that 192.168.2.1 did not send out any packets at all .
I changed the 192.168.2.1 with other matchine and the cable too, but the same case happened. Could be some hardware problem with eth0?
as to access-list , I used configuration as follow,
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname route
enable password xxxxxxxxxxxxxxxxxxxxxxxxx
memory-size iomem 15
ip subnet-zero
no ip source-route
no ip domain-lookup
ip inspect max-incomplete high 2500
ip inspect max-incomplete low 1500
ip inspect one-minute high 1500
ip inspect one-minute low 1000
ip inspect tcp max-incomplete host 150 block-time 0
ip inspect name Ethernet_1 ftp
ip inspect name Ethernet_1 tcp
ip inspect name Ethernet_1 udp
ip inspect name Ethernet_0 ftp
ip inspect name Ethernet_0 tcp
ip inspect name Ethernet_0 udp
ip audit notify log
ip audit po max-events 100
interface FastEthernet0/0
description connected to internet
ip address 192.168.2.1 255.255.255.0
ip access-group 101 in
ip inspect Ethernet_0 in
duplex auto
speed auto
ntp disable
no cdp enable
interface FastEthernet0/1
description connected to Lan
ip address 192.168.3.1 255.255.255.0
ip access-group 100 in
ip inspect Ethernet_1 in
duplex auto
speed auto
ntp disable
no cdp enable
router rip
version 2
passive-interface FastEthernet0/0
network 192.168.2.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
no ip http server
ip pim bidir-enable
logging 192.168.2.254
access-list 100 permit ip any any
access-list 100 permit icmp any any
access-list 101 permit icmp any any
access-list 101 permit ip any any
no cdp run
line con 0
exec-timeout 0 0
login
line aux 0
line vty 0 4
password xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
login
end
75
