02-18-2002 03:06 PM - edited 03-01-2019 08:31 PM
Tengo un dispositivo MagIc 9000 de Schlumberger que se conecta vía X.28 a una PSTN la cual llega a un aquipo AS5300 a través de un E1 PRI y luego es enviada a un servidor de aplicación que toma los datos y los procesa. Mi problema es que al lograr conectar el equipo MagIc al servidor de aplicación se desconecta en 5 segundos y no me deja realizar la transacción. Me arroja el mensaje de desconexión 0x8090 - Normal call clearing. Estoy probando con "Autocommand Telnet "IP Address server" PORT /stream", pero no logro mantener la comunicación por mucho tiempo.
Alguien a configurado un AS5300 con estos dispositivos MagIc 9000 de Schlumberger ????
--- Moderator Edit ---
--- Rough Translation provided by http://babelfish.altavista.com--
Device MagIc 9000 of Schlumberger who connects via X.28 to a PSTN which arrives at aquipo AS5300 through E1 PRI and soon it is sent to an application server that takes the data and it processes them. My problem is that when obtaining to connect the MagIc equipment to the application server it becomes disconnected in 5 seconds and does not let to me make the transaction. 0x8090 throws the message to me of disconnection - Normal call clearing. I am proving with " Autocommand telnet " IP address server " PORT / stream ", but profit not to maintain the communication for a long time.
Somebody to formed a AS5300 with these devices MagIc 9000 of Schlumberger?
03-01-2002 01:42 PM
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
