Problem with DDR ISDN
Hi, I have a problem with a router 3600 that calls another on DDR.
This is the configuration of the Cisco 3600
username catastro password 0 tycsa
ip subnet-zero
isdn switch-type basic-net3
isdn tei-negotiation first-call
interface BRI1/0
description conexion con el Catastro
ip address 192.169.0.2 255.255.255.0
no ip directed-broadcast
encapsulation ppp
dialer idle-timeout 300
dialer map ip 192.169.0.1 name catastro 842367064
dialer-group 2
no fair-queue
ppp authentication chap
ip classless
ip route 10.33.24.10 255.255.255.255 192.169.0.1
dialer-list 2 protocol ip permit
I don't have access to the other router but I have talked with his administrator and he told me that
he have put this:
username ayunta password 0 tycsa
I have made several debug in my router but I don't see where is the problem.
Can anybody help me?
debug ppp authentication
ayunta#debug ppp authentication
PPP authentication debugging is on
ayunta#ping 192.169.0.1
Sending 5, 100-byte ICMP Echos to 192.169.0.1, timeout is 2 seconds:
5d07h: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR1/0, TEI 64 changed to down
5d07h: %ISDN-6-LAYER2UP: Layer 2 for Interface BR1/0, TEI 64 changed to up.
5d07h: %LINK-3-UPDOWN: Interface BRI1/0:1, changed state to up
5d07h: BR1/0:1 PPP: Treating connection as a callout
5d07h: BR1/0:1 PPP: Phase is AUTHENTICATING, by both
5d07h: BR1/0:1 CHAP: O CHALLENGE id 82 len 27 from "ayunta"
5d07h: BR1/0:1 CHAP: I CHALLENGE id 93 len 36 from "catastro"
5d07h: BR1/0:1 CHAP: O RESPONSE id 93 len 27 from "ayunta"
5d07h: BR1/0:1 CHAP: I SUCCESS id 93 len 4.
5d07h: %LINK-3-UPDOWN: Interface BRI1/0:1, changed state to down.
5d07h: BR1/0:1 CHAP: O CHALLENGE id 83 len 27 from "ayunta"
5d07h: BR1/0:1 CHAP: I CHALLENGE id 94 len 36 from "catastro"
5d07h: BR1/0:1 CHAP: O RESPONSE id 94 len 27 from "ayunta"
5d07h: BR1/0:1 CHAP: I SUCCESS id 94 len 4.
Success rate is 0 percent (0/5)
ayunta#
5d07h: BR1/0:1 CHAP: O CHALLENGE id 84 len 27 from "ayunta"
5d07h: BR1/0:1 CHAP: I CHALLENGE id 95 len 36 from "catastro"
5d07h: BR1/0:1 CHAP: O RESPONSE id 95 len 27 from "ayunta"
5d07h: BR1/0:1 CHAP: I SUCCESS id 95 len 4
ayunta#
ayunta#undebug all
All possible debugging has been turned off
ayunta#
Is there any problem with the authentication?
Thanks in advance
Bronze
Re: Problem with DDR ISDN
I see that you are sending a CHAP Challenge, but catastro is not sending a response. I suggest you remove the "ppp authentication chap" command and try pinging catastro again. If it works, you have found the problem. Find out why the other router is not sending the CHAP response. Ask if catastro has the command "ppp chap refuse callin" in its interface.
Good Luck,
Mark
Configure following command under interface bri1/0 on "ayunta" for one way chap
ppp authentication chap callin
so that "ayunta" will not send challenge, Only "catastro" who receives the call will challenge to authenticate "ayunta". With that you should see IPCP negotiation works ok.
111
