Problem with dialer bundling channels
I have a a dial-in router (3660) which external users dial-into via modems or ISDN. Authentication of users is via Securid tokens and CiscoSecure ACS. Token caching is enabled on ACS so that ISDN users can bring up a second b-channel. If one ISDN user dials in, everything is O.K. However, when the second ISDN user dials in, the dialer tries to add the second user's b-channels to the first user's, and authentication for the second user fails and call is dropped.
Any thoughts on why this is happening? Should I be using virtual templates and dialer rotary-groups ?
See partial config below:
aaa new-model
aaa authentication login default group radius local
aaa authentication login NO_RADIUS line
aaa authentication login CONSOLE none
aaa authentication ppp default if-needed group radius local
aaa authorization network default group radius
aaa accounting delay-start
aaa accounting exec default start-stop group radius
aaa accounting network default start-stop group radius
aaa accounting connection default start-stop group radius
interface Serial1/0:15
no ip address
encapsulation ppp
dialer pool-member 1
isdn switch-type primary-net5
isdn incoming-voice modem
no cdp enable
ppp multilink
interface Group-Async1
ip unnumbered FastEthernet0/0
ip helper-address <ip address omitted>
encapsulation ppp
dialer in-band
dialer idle-timeout 1200
dialer fast-idle 180
dialer-group 1
async mode interactive
peer default ip address pool MyPool
ppp callback accept
ppp authentication pap ms-chap
group-range 65 94
interface Dialer1
description "ISDN users come in here"
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp callback accept
ppp multilink
ip local pool MyPool <ip address omitted> <ip address omitted>
1 REPLY
Re: Problem with dialer bundling channels
Make sure that the usename of both the users are different.. Since ppp multilink is turned on, two channles will be bundeled togather if the same username is received during authentication. We need to see the debug for following to see the problem,
debug isdn q931
debug ppp nego
debug ppp authentication
debug aaa authentication
debug aaa authorizion
debug aaa per
Now let first user dialin and connect and issue "sh users", let second user dialin and capture the debug for both the calls and post it here,
Now you do need virtual-template if user specific authorization attributes are downloaded from AAA to router..
85
