Community Member
Problem with downloadable ACL's with ISDN
I have interesting problem.
Problem is related to Cisco 3725 with E1 and digital modems used as access server.
Access server is using Cisco Secure ACS for AAA purposes.
I defined downloadable access list as RADIUS cisco av-pair.
It works fine with modem lines, but it does not with if you try dial using regular ISDN connection.
With ISDN connection authorization fail. After unconfiguring av-pairs on ACS everything works fine.
Configuration for multilink:
multilink virtual-template 1
interface Virtual-Template1
ip unnumbered Loopback0
Configuration for ISDN is:
interface Serial1/0:15
ip nat inside
encapsulation ppp
dialer-group 1
isdn switch-type primary-net5
isdn incoming-voice modem
no fair-queue
no cdp enable
ppp callback permit
ppp authentication chap aaaPPP
ppp authorization aaaPPP
ppp multilink
Configuration for digital modems:
interface Group-Async1
ip nat inside
encapsulation ppp
async mode dedicated
ppp callback permit
group-range 65 94
Configuration for AAA:
aaa authentication ppp aaaPPP group radius
aaa authorization network aaaPPP group radius
aaa accounting network default start-stop group radius
radius-server host <ACS IP address> auth-port 1645 acct-port 1646 key <ACS key>
I tried to find any solution on CCO, but I failed.
Have anybody any idea? Is it unsupported feature?
BTW: I tried to check downloadable ACL's also in "pure" enviroment - without callback and multilink feature and it also does work.
Bronze
Re: Problem with downloadable ACL's with ISDN
Try out dialer rotary-group instead of dialer group, because dialer group can only be associated with one interface at a time.
Please have a look at
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_configuration_example09186a0080094557.shtml
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_command_reference_chapter09186a00801a7e9b.html#wp1181417
Community Member
Unfortunately I was not able to read post for long time.
The problem is not with dialer-group.
I have already try configuration with dialer interface. Using dialer interface user is able to authenticate and authorize but access list are still not loaded to the router.
I use cisco av-pair ip:inacl# statement on radius server. As I mentioned it works fine with async interfaces but it does not with isdn pri interface.
113
