Problem with EtherChannel
I have created Etherchannel on Cisco 3524 between port 1-2, 3-4, and 5-6 and they are connected to 3 Dell Servers.
Server 1 (Dual Nic) connected to port 1-2
Server 2 (Dual Nic) connected to port 3-4
Server 3 (Dual Nic) connected to port 5-6
The problem is after a few minutes, the 3 servers would lose connection. Another few minutes later, the connection would be good. And another few minutes, the connection is lost. It is basically intermittent.
Port 24-25 are also Etherchannel and connected to another cisco switch, and it is working fine. The problem is only b/w servers and the switch.
I thought it was the Spanning tree, so I disabled these ports from learning (STP Learning = Disabled), but the results were the same.
Any Idea?
Re: Problem with EtherChannel
What mode are the channels in? On? Auto? Desireable?
-Bo
on mode..
You have enabled port teaming on the NICs on the Dell systems?
Yes, NICs are teamed properly.
110
