You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Problem with GLBP
Hi , I have 2 router to connect to Internet and I need to configuere GLBP, I try but doesn't work.
I need to help?
I send the this configuration
Primary router
interface FastEthernet0/0
duplex auto
speed auto
glbp 10 ip 192.168.1.10
interface Serial0/0
ip address 172.16.10.2 255.255.255.252
ip route 0.0.0.0 0.0.0.0 172.16.10.2
Secondary Router
ip address 200.1.1.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
ip address 192.1.1.2 255.255.255.252
ip route 0.0.0.0 0.0.0.0 192.1.1.2
software version in c2600-advsecurityk9-mz.123-1a
  • Other Network Infrastructure Subjects
1 REPLY
Re: Problem with GLBP
for start it appears your static routes are incorrect. Try changing the routes to the IP address of the remote router as opposed to the local router.
Then, and here is the problem, your ethernet interfaces must be on the same subnet. Change your second routers ethernet ip address to 192.168.1.xxx
Your config will be blocking GLBP packets.
Ensure each router knows about the other one: show glbp
Problem solved or does this create a new problem ??
87
