Webcast-Catalyst9k
Problem with IGX nodes being unreachable.
I am facing a problem which seems to be of database incosistency.The symptoms are two nodes(not directly connected via a Trunk) are reachable from intermediate nodes but show as "unreachable" to each other.
On NODE1:
NodeName Alarm
NODE1 Minor
NODE2 Minor
NODE3 MAJOR
NODE4 UNRCH
NODE5 MAJOR
NODE6 Minor
On NODE4:
NodeName Alarm
NODE1 UNRCH
NODE2 Minor
NODE3 MAJOR
NODE4 Minor
NODE5 MAJOR
NODE6 Minor
On NODE3:(Intermediate Node)
NodeName Alarm
NODE1 MAJOR
NODE2 Minor
NODE3 MAJOR
NODE4 Minor
NODE5 MAJOR
NODE6 Minor
As indicated,the two nodes(NODE1&NODE4)in question are reachable from the intermediate nodes(NODE3,2,5,6) but they are unreachable from each other.Inspite of manually forcing a database update,the problem still persists.Any help would be highly appriciated.
Re: Problem with IGX nodes being unreachable.
Hello Sunil,
Your question looks like case E850013 opened on 12 Dec for the same problem. Is this the case?
Yes it is..the problem is solved now.I guess it is apparently a bug.The problem has been sorted out.
91
