Problem with IOS upgrade into router 7206 VXR
I tried to load a new IOS in a Cisco router 7206 VXR (c7200-js-mz.121-5c.E12.bin) in the Flash Card. The new IOS is loaded in the PCMCIA correctly but when I reload the router I see the following error: %SYS-6-READ_BOOTFILE_FAIL: disk0:c7200-js-mz.121-5c.E12.bin File boot failed --File not accessible, and the router start with the BOOT Image (C7200-BOOT-M), Version 12.0(13)S.
I configured also the router for start with the correct IOS but without success.
If I type sh flash I see:
Open device slot0 failed (Bad device info block). I don't know how resolve this problem
Silver
Re: Problem with IOS upgrade into router 7206 VXR
try to reformat your flash card and copy the image back in from your tftp server
router# format disk0:
router#squeeze disk0:
Silver
also a good way to test before you reload the box is to do a 'verify' . This will ensure the box sees the image rior to reloading
Router#sh bootvar
BOOT variable = slot0:c7200-js-mz.120-7.T,1;slot0:,1;bootflash:,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Configuration register is 0x102
router#verify slot0:c7200-js-mz.120-7.T
CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
Verified slot0:c7
331
