08-09-2002 01:22 AM - edited 03-02-2019 12:34 AM
Hi, I `ve got a problem with a remote access connection with a ISDN TA x.75
(no ppp authentication) to a c3640 access router. Below you can see the configuration and the debug output thanks for your help.
hostname tpie1o
enable password 7 00011512005219030C35
modem country mica switzerland
ip subnet-zero
ip address-pool local
vty-async
vty-async keepalive 0
vty-async virtual-template 1
isdn switch-type primary-net5
call rsvp-sync
controller E1 0/0
pri-group timeslots 1-31
description ISDN PRI 031-305 18 64
controller E1 0/1
interface Loopback0
ip address 172.22.5.22 255.255.255.255
interface Loopback1
description default-gateway for ppp users
ip address 172.22.216.129 255.255.255.192
interface Serial0/0:15
no ip address
encapsulation ppp
ip tcp header-compression passive
dialer rotary-group 1
autodetect encapsulation ppp v120 lapb-ta
isdn incoming-voice modem 64
no cdp enable
interface Serial1/0
no ip address
shutdown
serial restart-delay 0
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface FastEthernet2/0
ip address 172.22.220.10 255.255.255.0
speed 100
full-duplex
interface Virtual-Template1
ip unnumbered Loopback1
peer default ip address pool eft2000
interface Group-Async1
encapsulation ppp
no ip mroute-cache
async mode interactive
group-range 97 126
interface Dialer1
encapsulation ppp
dialer in-band
dialer-group 1
no cdp enable
ip local pool eft2000 172.22.216.130 172.22.216.190
ip classless
ip route 0.0.0.0 0.0.0.0 172.22.220.254
ip http server
ip pim bidir-enable
dialer-list 1 protocol ip permit
dial-peer cor custom
line con 0
line 97 126
flush-at-activation
modem InOut
autoselect during-login
autoselect ppp
line aux 0
line vty 0 4
password 7 0603093548471B1C0603
login
transport input telnet
line vty 5 34
exec-timeout 0 0
no login
rotary 1
autocommand ppp neg
transport input v120 lapb-ta
autoselect ppp
end
tpie1o#sh deb
LAPB Terminal Adapter:
LAPB TA events debugging is on
PPP:
PPP protocol negotiation debugging is on
ISDN:
ISDN Q931 packets debugging is on
ISDN Q931 packets debug DSLs. (On/Off/No DSL:1/0/-)
DSL 0 --> 31
1 - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
tpie1o#
19:42:14: ISDN Se0/0:15: RX <- SETUP pd = 8 callref = 0x0110
19:42:14: Sending Complete
19:42:14: Bearer Capability i = 0x8890
19:42:14: Channel ID i = 0xA98396
19:42:14: Calling Party Number i = 0x01, 0x83, '0319140470', Plan:ISDN,n
19:42:14: %LINK-3-UPDOWN: Interface Serial0/0:21, changed state to up
19:42:14: ISDN Se0/0:15: TX -> CALL_PROC pd = 8 callref = 0x8110
19:42:14: ISDN Se0/0:15: TX -> CONNECT pd = 8 callref = 0x8110
19:42:14: ISDN Se0/0:15: RX <- CONNECT_ACK pd = 8 callref = 0x0110
19:42:14: ISDN Se0/0:15: CALL_PROGRESS: CALL_CONNECTED call id 0x15, bchan 21, 0
19:42:14: LAPB-TA: Autodetect trying to detect LAPB on Se0/0:21
19:42:14: sampled pkt: 2 bytes: 1 3F.. match
19:42:14: LAPBTA: get_ll_config: Serial0/0:21
19:42:14: LAPBTA135: vty allocated for Se0/0:21
19:42:14: LAPBTA135: process 98
19:42:14: Se0/0:21: LAPB-TA started
19:42:14: LAPBTA: service change: LAPB physical layer up, context 6272B658 inten
19:42:14: LAPBTA: service change: , context 6272B658 up
19:42:14: Vi2 PPP: Phase is DOWN, Setup [0 sess, 1 load]
19:42:14: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
19:42:14: Vi2 PPP: Treating connection as a dedicated line
19:42:14: Vi2 PPP: Phase is ESTABLISHING, Active Open [0 sess, 1 load]
19:42:14: Vi2 LCP: O CONFREQ [Closed] id 1 len 20
19:42:14: Vi2 LCP: ACCM 0x000A0000 (0x0206000A0000)
19:42:14: Vi2 LCP: MagicNumber 0xE458B818 (0x0506E458B818)
19:42:14: Vi2 LCP: PFC (0x0702)
19:42:14: Vi2 LCP: ACFC (0x0802)
19:42:14: LAPBTA: cfg_idb Serial0/0:21
19:42:15: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0:21, changedp
19:42:16: Vi2 LCP: TIMEout: State REQsent
19:42:16: Vi2 LCP: O CONFREQ [REQsent] id 2 len 20
19:42:16: Vi2 LCP: ACCM 0x000A0000 (0x0206000A0000)
19:42:16: Vi2 LCP: MagicNumber 0xE458B818 (0x0506E458B818)
19:42:16: Vi2 LCP: PFC (0x0702)
19:42:16: Vi2 LCP: ACFC (0x0802)
19:42:18: Vi2 LCP: TIMEout: State REQsent
19:42:18: Vi2 LCP: O CONFREQ [REQsent] id 3 len 20
19:42:18: Vi2 LCP: ACCM 0x000A0000 (0x0206000A0000)
19:42:18: Vi2 LCP: MagicNumber 0xE458B818 (0x0506E458B818)
19:42:18: Vi2 LCP: PFC (0x0702)
19:42:18: Vi2 LCP: ACFC (0x0802)
19:42:19: ISDN Se0/0:15: RX <- DISCONNECT pd = 8 callref = 0x0110
19:42:19: Cause i = 0x8090 - Normal call clearing
19:42:19: %ISDN-6-CONNECT: Interface Serial0/0:21 is now connected to 031914047
19:42:19: %ISDN-6-DISCONNECT: Interface Serial0/0:21 disconnected from 0319140s
19:42:19: %LINK-3-UPDOWN: Interface Serial0/0:21, changed state to down
19:42:19: LAPBTA: service change: LAPB physical layer down, context 6272B658 inn
19:42:19: LAPBTA: stop 6272B658 line 135
19:42:19: LAPBTA135: stopped, removing lapb, disconnecting
19:42:19: LAPBTA: removing context 6272B658
19:42:19: ISDN Se0/0:15: TX -> RELEASE pd = 8 callref = 0x8110
19:42:19: %LINK-5-CHANGED: Interface Virtual-Access2, changed state to reset
19:42:19: Vi2 LCP: State is Closed
19:42:19: Vi2 PPP: Phase is DOWN [0 sess, 1 load]
19:42:19: LAPBTA: close 6287E94C, line 135
19:42:19: ISDN Se0/0:15: RX <- RELEASE_COMP pd = 8 callref = 0x0110
19:42:19: Vi2 IPCP: Remove route to 172.22.216.147
19:42:20: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0:21, changedn
tpie1o#
08-13-2002 11:02 AM
I'm not sure where the problem is, although I suspect the telco initially. We send out LCP CONFREQ packets, but do not receive in any data. Then 5 seconds after the connection was established the remote end tears it down. Your config looks OK, with the exception of the "autocommand" under the virtual-template interface; normally that command only applies to the physical interfaces. I would suggest you try to confirm if the remote dialin client is receiving any of the PPP packets that the cisco is sending out. This link here may help some, too:
