Community Member
Problem with Multilink and Cisco 3600 serie
Our Router calls the internet through a ISDN line. When we use multilink after a 2 hours the link stops and we have to reset the module or router. Then it works fine for a while until the problem yet occurs. When we only use one channel of the ISDN line it works fine. What can be the problem?
Has anyone seen this problem before?
1 REPLY
Re: Problem with Multilink and Cisco 3600 serie
We need to debug the issue for why the links went down. We need to troubleshoot that ppp multilink problem.
Here is the best url for that
http://www.cisco.com/warp/public/131/mppp-ddr.html
Does the 2nd b channel ever comeup and added to the bundles at client router? Here is the url for "Troubleshooting Second B-channel Call Failures on ISDN BRI Links"
http://www.cisco.com/warp/public/471/ppp_multilink_ts.html
http://www.cisco.com/warp/public/131/multippp_add_bchannels.html
See if those links helps to troubleshoot the issue.
Configure "dialer load-threshold 2" under the interface dialing to internet so that both the links can come up one aftre the other. Collect the following debug when both the links come up
debug isdn q931
debug dialer
debug ppp nego
debug ppp multilink
Once both the links come up, issue
sh users
sh ppp multilink
Post it here with config and version of image.
121
