Webcast-Catalyst9k
problem with my cable config
i have a cisco router 1605 R series and i have configured my router with DHCP. when i type sh ip interface brief i see my public ip.
i ping known public ip addreses i get replies with no problem
but with my pc i can't ping any ip address outside and can't go to the internet.(my isp's dns are configured locally in my pc) do i have a problem in
my config?? Router#sh run
Building configuration...
Current configuration : 1292 bytes
version 12.3
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
enable secret xxxxx
username xxx password xxx
aaa new-model
aaa authentication login default local
aaa authentication ppp default if-needed local
aaa session-id common
ip subnet-zero
no ip domain lookup
ip dhcp excluded-address 192.168.0.254
ip dhcp pool client
import all
network 192.168.0.0 255.255.255.0
default-router 192.168.0.254
dns-server x.x.245.106
lease infinite
interface Ethernet0
ip address 192.168.0.254 255.255.255.0
ip access-group 100 in
ip access-group 100 out
ip nat inside
interface Ethernet1
ip address dhcp
ip nat outside
ip nat inside source route-map nonat interface Ethernet1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Ethernet1
ip route 192.168.0.0 255.255.255.0 Ethernet0
ip http server
no ip http secure-server
access-list 10 permit any
access-list 100 permit ip any any
line con 0
transport preferred all
transport output all
line vty 0 4
password xxxxx
transport input all
Re: problem with my cable config
hi momo51,
you can create an access-list for your internal network
access-list 1 permit 192.168.0.0 255.255.255.0
access-list 1 deny any
and then create nat:
ip nat inside source list 1 pool yourpoolname overload
ip nat pool yourpoolname isp.given.ip.add netmask isp.given.netmask.add
and don't forget to check ip nat inside (on your internal interface) and ip nat outside (external)
good luck,
-b.go-
VIP Purple
as B.Go said, you need to create an access list to source the inside addresses. In your configuration you reference a route-map that does not exist, so your PC address never gets translated. The following config should work better:
version 12.3
hostname Router
boot-start-marker
boot-end-marker
enable secret xxxxx
aaa new-model
ip subnet-zero
no ip domain lookup
ip dhcp pool client
import all
lease infinite
interface Ethernet0
ip nat inside
interface Ethernet1
ip address dhcp
ip nat outside
ip nat inside source list 1 interface Ethernet1 overload
ip classless
ip http server
access-list 1 permit 192.168.0.0 0.0.0.255
line con 0
line vty 0 4
password xxxx
transport input all
Georg
THX!
it works !
but i don'tunderstand how come we don't have to apply ip access-group on interface e0 et e1
such on e0
ip access-group 1 out??
VIP Purple
putting access-lists on the Ethernet interfaces is not necessary for NAT to work. Access list 1 just tells the router which internal IP addresses to consider for translation.
Let us know if that is not clear :)
Georg
OK! but can you still used access-list on interfces to controll the traffic in the lan or wan; with the nat implemented.
i always thought that when you configure something you are have to enable on the interface after??
but thanks for your help
I would think that you would use the access list if you have certain pc's that you would not want to access the internet or some other destination that you can route to. Or vise versa, allow certain pc's to access the internet.
I'm I wrong here?
BE
hi momo51,
the acl no. 1 is only for defining interesting traffic to be NATed. You can apply additional acls to incoming ethernet. So the denied hosts can't be NATed since they are not allowed to enter the incoming interface.
hope this will help. good luck.
regards,
-b.go-
89
