Problem with NAT and Multilink PPP on Leased Line
we are running a leased line with a 2 channel ISDN connection.
The channels are bundled with multilink ppp.
The connection works, all line protocols are up, and
pings from both sides go through.
But if we try to send mail between the both mailservers at each
end of the connection the connection stops after a few packets
and times out after a few minutes.
Again - the connection works, but traffic to Router B
stops are a while, when sending mail to the server behind router B.
Do I need to chaneg the MTU for the Multilink connection ?
Or something else ?
Perhaps someone can help, here are extracts of the configs of both routers.
router A
multilink virtual-template 2
isdn leased-line BRI1/4
interface BRI1/4:1
ip unnumbered Virtual-Template2
no ip directed-broadcast
encapsulation ppp
no ip route-cache
no keepalive
no fair-queue
ppp multilink
interface BRI1/4:2
encapsulation ppp
no ip route-cache
no keepalive
no fair-queue
ppp multilink
interface Virtual-Template2
ip address 212.108.164.161 255.255.255.252
no keepalive
ppp multilink
Router B
multilink virtual-template 1
isdn leased-line BRI1/1
interface BRI1/1:1
ip unnumbered Virtual-Template1
encapsulation ppp
no ip route-cache
no keepalive
no fair-queue
ppp multilink
interface BRI1/1:2
encapsulation ppp
no ip route-cache
no keepalive
no fair-queue
ppp multilink
interface Virtual-Template1
ip address 212.108.164.162 255.255.255.252
ip nat outside
no ip route-cache
no keepalive
ppp multilink
ip nat inside source list 48 interface Virtual-Template1 overload
ip nat inside source static tcp 192.1.1.48 110 interface Virtual-Template1 110
ip nat inside source static tcp 192.1.1.48 25 interface Virtual-Template1 25
ip nat inside source static tcp 192.1.1.48 22 interface Virtual-Template1 22
ip nat inside source static tcp 192.1.1.48 23 interface Virtual-Template1 23
ip route 0.0.0.0 0.0.0.0 212.108.164.161 50
access-list 48 permit 192.1.1.0 0.0.0.255
249
