problem with NAT on 2600
We can't get any translations to show on our router when connecting from the outside. I was looking at the config and was wondering if the sub-interface portion was correct. I am curius to know that if I put an IP on fa0/1 (instead of fa0/1.1) if this works the same way? below is a snippet of what I am talking about.
interface FastEthernet0/1
description LAN Interface to CJF
ip address xxx
ip access-group 103 in
ip access-group 103 out
ip nat outside
no ip mroute-cache
duplex auto
speed auto
interface FastEthernet0/1.2
encapsulation dot1Q 3
ip address xxx
ip helper-address 10.100.1.28
no ip redirects
ip nat inside source statice "local IP" "outside IP" extendable
Re: problem with NAT on 2600
What you get by putting an IP on the interface is a connection with the native vlan.
This will only work when the other side also supports packets -without- dot1Q encapsulation.
Leo
Ok. Then 1 more question. Is it possible to do a static NAT translation to an IP that is not defined on an interface? Does the below configuration work?
interface FastEthernet0/0
description WAN Interface To Wireless
ip address 192.168.20.1 255.255.255.0
ip access-group 100 in
ip access-group 100 out
no ip mroute-cache
duplex auto
speed auto
interface Serial0/0
ip address 192.168.253.250 255.255.255.252
ip nat inside
ip address 10.100.112.1 255.255.248.0
ip nat outside
no ip mroute-cache
duplex auto
speed auto
ip address 10.100.128.1 255.255.248.0
no ip redirects
ip nat inside source static 172.16.1.3 10.100.112.10 extendable
all I see in the nat table is the following:
HCJFROUTER#sh ip nat translations
Pro Inside global Inside local Outside local Outside global
--- 10.100.112.10 172.16.1.3 --- ---
I am trying to figure out why I can't NAT and reach 172.16.1.3 when going to 10.100.112.10
You have to have 2 interfaces doing nat if you want to nat. An inside and an outside. You do not have ip nat inside on any interface. To do natting you must go from one nat interface to another nat interface. Look at the example links I sent previously. This example config you are showing us will not do any nat. I do not think the ip nat inside source will even work properly without a "ip nat inside" on an interface that it is set up for.
If this helps please rate.
Mike
This configuration is in complete. Here is a link that can get you started.
http://www.cisco.com/en/US/customer/tech/tk648/tk361/technologies_configuration_example09186a0080093f8e.shtml
This TAC case has an example for extendable use.
http://www.ciscotaccc.com/iprout/showcase?case=K75019454
121
